cossie manifold common fault
well pissed off my old mans manifold had cracked on his 4x4 inside where the turbo bolts to it and someone off here pmd me saying he had 1 so i sent the money got it today and guess what a crack in the same place im well pissed about it as i asked if it had any cracks before paying and was told non att all otherwise i wouldnt of brought it so it must be a common thing on 4x4s so next time ya turbos off take a look
Re: cossie manifold common fault
if i get an uncracked 1 whick i will how do i prevent it from cracking what about a spec r turbo damper they any good ?its got a t34 if that makes any difference to it fitting
lol his had 1 so whats the best damper around to fit t34 on a 4x4
but its not just a case of changing the manifold is it theres other things involved aint there right im goin in search of a spec r 1
If you change to 2WD fanimold does that mean you have to change your downpipe to a 2WD one?
I've heard the 2WD manifolds are a pain to fit with the engine in, is this just because they are much bigger or because you need some decent shaped tools for the job?.....do they use the same studs as the 4x4?
Originally Posted by Glenn5
dont the spec-r 1s only fit a 2wd head
The idea is you fit a damper when you have the 2wd manifold and 4x4 head combination, as the 4x4 head doesn't have the lug that a 2wd head has to run the std damper.
Why you'd want to run a damper on a 4x4 manifold is beyond me.
yeah ive looked at it and see that its a heat issue what pisses me even more is that the 1 that turned up today was the 1 i payed good money for
0-60 in 17 seconds (eek)
i have had the same problem the crack just gets bigger iam going 2wd manifold no uncracked 4wd ones i do no GGR has new ones but dont no wot price from ford they are over 600 quid. getting t4 turbo hanger from spec r as my car is the show car as well as t38 turbo which turbo technics changed over for free as turbo was still new exhaust should fit according to MAD
Originally Posted by richm
like this one?????
been like it for years, very common, and hasn't caused a problem...
Mine is like that any any other 4x4 manifold I've seen. It isn't crack to the outside and it doesn't cause any problems.
like this one?????
yeah, exactly, the crack in mine is just on the internal casting web, no sign of it at the outside.
It's easiest to check it with a flash-light
th3 2 i have are cracked inside and out 1 has been welded on the outside the other hasnt but ive recently got 1 of a guy from here that only has it on the inside so thats whats gonna get used its just abit of a worrie last thing we want is it to come apart and fly off into the new t34
CossieCrew - Was the person who sold you the cracked one called Andy perchance?
My manifold has a crack in it too, has had for at least 2 years, and doesnt cause any chew at all
You can have them welded up as well if needed.
Neil.
Neil.
Have anyone used steel exhaust manifold in a Cosworth, do they generally give extra horsepower, and who makes them? Atleast in N/A engines steel manifolds gain quite a few bhp compared to the cast iron scrap.
wheelwizardrefurbs
21-09-2015 06:42 AM
DixieTheKid
14-09-2015 09:04 PM
Si B
12-09-2015 06:49 AM
