Sponsored by:
Sponsored by:
Ka 2004 1.3 bad starting batt fine.
Old 08-02-2019, 10:03 AM
nickjaxe
nickjaxe's Avatar
Default Ka 2004 1.3 bad starting batt fine.
Hi all...my son in laws 2004 ka 1.3 has an intermittent not wanting to start when cold.
The battery is fine it turns the engine over quite quickly and doesn't give up.
This is the second time its done this and he has ended up catching a train to work and arriving late.
I was with him this morning when he tried to start it...key in crank over the engine...it tries to fire but wont fully start this is without throttle...
Give it throttle and it wont even try to fire.
When it failed last week he left it 30 mins and tried again and started an ran as normal.
I suspected a part blocked fuel filter old one we found out has not been changed in 100.000mls...bought a new one but not been able to fit it yes due stuck quick release fitting...looking into that at present.
How would we test the fuel pump?
Any ideas guys.
Old 08-02-2019, 10:08 AM
smiley
smiley's Avatar
I use these for work had 3 now very reliable try spark plugs cheapest option first then starter motor I do 4k a month in mine drop the oil every 10k change plugs at 20k
Old 08-02-2019, 10:11 AM
haz87
haz87's Avatar
Sounds like its flooding if its starting 30mins later tbh. Easily checked, but a service certainly wont do any harm as the plugs/leads etc could be breaking down and producing a poor spark
Old 08-02-2019, 10:17 AM
nickjaxe
nickjaxe's Avatar
Plugs quite new.
Old 08-02-2019, 07:36 PM
GVK.
GVK.'s Avatar
Never start these with foot on throttle, will cause flooding as above.
studabear
studabear's Avatar
Can you look at the live data and see what the coolant temp sensor is reading from cold?
Old 08-02-2019, 09:53 PM
nickjaxe
nickjaxe's Avatar
Studabear...I have a basic fault code reader and a more in depth one on an old laptop...I can give that a try looking at the coolant temp...why what are you thinking.
Managed to replace the very old fuel filter this afternoon...while it was off I turned on the ignition to see what flow the petrol pump was giving...petrol blasted out of the pipe.
Will see how it goes now.
Starter motor is fine spins engine quite fast...plugs changed around a year ago I think...but I will take em out and have a look and re gap if necessary.
Old 08-02-2019, 10:42 PM
scoooby slayer
scoooby slayer's Avatar
Coolant temp sensor I think will be what tells the ECU temperature so it can add extra fuel for you cold start ie choke
Old 08-02-2019, 11:26 PM
nickjaxe
nickjaxe's Avatar
Would a duff sensor cause a fault warn light...non showing.
Old 09-02-2019, 03:11 PM
studabear
studabear's Avatar
Yes it could.
Old 09-02-2019, 04:41 PM
nickjaxe
nickjaxe's Avatar
Started ok today...fingers crossed.
motormaniac3000
22-02-2013 09:24 AM
B19LRW
17-01-2005 10:09 PM
Ginge !
12-12-2004 09:16 PM
apples24
22-11-2004 09:10 PM
xrsi
12
18-09-2004 10:37 AM
Quick Reply: Ka 2004 1.3 bad starting batt fine.
