Oppliger cosworth inlet manifold throttle body question
Old 01-09-2018 | 04:25 PM
jonesymk2's Avatar
jonesymk2
Default Oppliger cosworth inlet manifold throttle body question
I've just bought an oppliger inlet,I've bolted the throttle body up and need some help with the linkage,I can't find any pictures of how people have connected the throttle cable as it will now be mounted behind the throttle body,does anybody have and pictures of what needs to be done please
Old 01-09-2018 | 05:28 PM
Caddyshack's Avatar
Caddyshack
Is it similar to the hart setup where you have a bracket to reverse the pull?
oppliger should be able to tell you, ask him a question on Facebook
Old 01-09-2018 | 06:33 PM
jonesymk2's Avatar
jonesymk2
Yes from pictures I can find on Google and here it looks like it could be similar to the hart and as inlets
Old 01-09-2018 | 07:22 PM
Caddyshack's Avatar
Caddyshack
Speak to oppliger and mk motorsport, I think you just need the simple bracket.
it is annoying when you buy an expensive part and the seller doesn’t tell you the simple fixes you need too.
Old 01-09-2018 | 10:11 PM
BillyEdmonds's Avatar
BillyEdmonds
The same thing happened to me when I bought an MIS manifold from Oppliger. No throttle cable bracket solution.
I bought the Anembo Engineering bracket. Perfect fit.
Old 02-09-2018 | 10:03 AM
jonesymk2's Avatar
jonesymk2
cheers mate I will have a look on eBay at anembo stuff see if I can find it
Old 02-09-2018 | 11:02 PM
cossynut2's Avatar
cossynut2
I bought a simple bracket when I got my A&S inlet which works well.
You can see the bracket in this photo.
Old 05-09-2018 | 01:41 PM
ossie cossie's Avatar
ossie cossie
would a normal throttle cable bracket fit?
Old 07-09-2018 | 03:03 PM
jonesymk2's Avatar
jonesymk2
I could probably make a bracket fit but it's the actual part on the throttle body where the cable clips onto that I'm having issues with
Old 09-09-2018 | 11:53 AM
jonesymk2's Avatar
jonesymk2
have you got a picture of the part on the throttle body where the cable clips onto please as that's what I'm having trouble finding
Old 09-09-2018 | 12:40 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
There was a picture on Facebook of spec-r making a custom bracket for a fancy manifold. Think I’ll drop mine off there this week as mine don’t move properly and puts the cable at a funny angle. I’ve a hart inlet with a small turbo escort t/b
Old 09-09-2018 | 05:46 PM
jonesymk2's Avatar
jonesymk2
What's the part like on the throttle body as that's what I'm having trouble with,I need it to pull from behind the throttle body so need a different part that bolts to the throttle body and can sort out the bracket for the cable at a later date
Old 09-09-2018 | 05:49 PM
ajamesc's Avatar
ajamesc
Mines a custom made bracket that was done for the small turbo t/b by joe is it? That makes the heart inlets. But it’s not very good it puts the cable at a bad angle. Needs a proper one making which it why I’ll not fuck about any more spec-r can do it then I know it’s done properly
Old 11-09-2018 | 08:24 PM
cossynut2's Avatar
cossynut2
Few more photos of my set-up
The cable runs nice and staight onto the throttle body.
I had to put an extra bit of heat protecting tube over the cable as it touches the header tank.
Old 15-09-2018 | 08:04 AM
jonesymk2's Avatar
jonesymk2
this is the part I need,i won't have any issues with the header tank as it's all in a mk4 escort so not using Sierra tanks
Old 17-09-2018 | 09:59 AM
R4N SS's Avatar
R4N SS
Im surprised this inlet hasnt been copied by Auto Specialist
Old 18-09-2018 | 12:16 AM
jonesymk2's Avatar
jonesymk2
Originally Posted by r4n ss
im surprised this inlet hasnt been copied by auto specialist
Adam-M
02-08-2018 07:09 PM
1374lee
28-03-2010 02:04 PM
bigryrs
04-07-2009 07:49 PM
Red16
16-12-2004 06:01 PM
