My Sierra XR6 running gear
Old 27-08-2018 | 06:18 PM
  #41
daiboy370's Avatar
daiboy370
No I have Cosworth calipers and discs on the rear
Old 27-08-2018 | 07:16 PM
  #42
steppy's Avatar
steppy
Don't forget there is 2 output flange sizes on the diffs the 2wd cosworth is 108mm and the 4wd cosworth and other non cosworth sierras are 100mm, do you know what your rear axle was off?
Old 27-08-2018 | 07:40 PM
  #43
daiboy370's Avatar
daiboy370
Yes I think it came of a Sierra 2 or 2.3 ltr Ghia
Old 27-08-2018 | 07:42 PM
  #44
steppy's Avatar
steppy
If that is the case the 2wd cosworth diff won't fit your existing set up due to the output flange size, your best bet is 4wd cosworth or xr4x4 diff
Old 27-08-2018 | 07:45 PM
  #45
daiboy370's Avatar
daiboy370
I’ve managed to acquire a Sierra Cosworth 2wd Diff and output shafts, what would I need to change to get that to fit?
Old 27-08-2018 | 08:09 PM
  #46
daiboy370's Avatar
daiboy370
If I have to change the rear beam then I will ?
Old 27-08-2018 | 08:41 PM
  #47
Mark V8's Avatar
Mark V8
Arrow shows where the difference is on the diff, you can cut the bracket off and make a new one to weld on, some people have cut the diff down to size.
Failing that you'll need a 7.5 inch beam, the stub shafts on the trailing arms are also different on 2WD Cosworth with the 108mm joints.
You might be able to swap the output shafts on the diff and keep your original setup, but I've never tried this, although I'm sure someone on here will know if that will work !
Old 27-08-2018 | 08:46 PM
  #48
daiboy370's Avatar
daiboy370
Yea thanks very much, I’ve been working on this car for a while! Really need to get it finished, as you say I can cut the diff or the beam to get the diff to fit, will suck it and see regarding the rest although I have a feeling it should be ok.
David
Old 27-08-2018 | 09:28 PM
  #49
Marc sierra's Avatar
Marc sierra
Just get a rear subframe from a Granada mk3. They all had the 7.5” diff, except for the Granada 2.9 4x4, which had the 7” diff just like the Sapphire Cosworth 4x4.
But first check what size diff you have now, it might already be 7.5”.
Old 27-08-2018 | 10:25 PM
  #50
cossynut2's Avatar
cossynut2
Originally Posted by daiboy370
Yea had lots of work done to it by Rick Wood Racing, this is why I’ve fitted a Cosworth drive train but to complete it I need a 2wd Cosworth box with LSD,
Looks super clean and will be a fast car once you sort out your drivetrain properly. Have you asked Rick Wood Racing for their advice as they are the Essex v6 experts?
Old 27-08-2018 | 11:00 PM
  #51
scoooby slayer's Avatar
scoooby slayer
How much does one of those Ric wood Essex v6s cost ?
Old 28-08-2018 | 06:43 AM
  #52
costina's Avatar
costina
Live long and prosper!!
1 x arm and 1x leg......
Old 28-08-2018 | 10:47 AM
  #53
R4N SS's Avatar
R4N SS
Originally Posted by Marc sierra
There are also normal Sierras that had a 7.5” diff, although there weren’t that many.
My 1991 Saph Ghia had a 7.5" non LSD Diff from factory - ford pretty much used what ever they had in the parts bin at the time i guess
Old 28-08-2018 | 12:03 PM
  #54
rallycross's Avatar
rallycross
looks like an interesting car, where does the 300 bhp number come from? Has it got a supercharger or turbo charger fitted as there is zero chance of a v6 Essex making that sort of power.
Old 28-08-2018 | 02:42 PM
  #55
daiboy370's Avatar
daiboy370
Old 28-08-2018 | 02:44 PM
  #56
daiboy370's Avatar
daiboy370
This is where the plus 300bhp comes from with the Essex V6, like most things if you spend enough you get the results. Mine is around 340-355 bhp.
Old 28-08-2018 | 05:58 PM
  #57
steppy's Avatar
steppy
iirc the output flange shafts differ in length between lsd and non lsd diffs so you would need the 100mm output shafts from an lsd diff to swap over into the 2wd diff
Old 01-09-2018 | 09:16 PM
  #58
daiboy370's Avatar
daiboy370
How easy or hard is it to change the oil seals on a 2wd Cosworth Diff?
Old 02-09-2018 | 02:36 PM
  #59
costina's Avatar
costina
I have my doubts too. We can only get 180bhp from a lancia 2.8 V6 which included 6 jenvey throttle bodies on omex. Custom cam and Simpson race exhaust.
Old 02-09-2018 | 03:21 PM
  #60
janus's Avatar
janus
I don't have any experience with the Essex V6 myself but if he's actually using custom cylinder heads I don't see why not.. it even says around 100 bhp/liter capability for those heads, and I can definitely see that happening when you wind it up to say 7krpm or more, as MarkV8 also said earlier here:
To get anywhere near that power at the wheels out of the Essex V6 it must be very highly strung!
I think that's actually why he has some trouble off the line, combined with the higher first gear of the T5 that makes perfect sense. Will be interesting to see how this all plays out and how the car is performing in the end, curious for the results
daiboy, as Marc (with a 'c' this time, haha) said absolutely check what you have in there NOW before we can give you any further advice here. You will also save yourself a lot of headaches if sth turns out to be different than from what we all were thinking and may save you from getting parts that end up not fitting your setup!
Is it just the 2.9 4x4? Not sure but I thought the Scorpio Mk1 ("Granada Mk3") also came with other 4x4 engines and I would guess they are all using the 7" rear diff.
One more Q for Mark: I didn't know that was all that is required, cutting where the arrow is to get a 7.5" diff fitted into a 7" rear beam?!
Good point on the shafts though.. length (LSD or open diff) and interface (bolted or push-in type) as well as maybe the flange (100mm vs. 108mm of the Cossie).
Old 02-09-2018 | 06:34 PM
  #61
Mark V8's Avatar
Mark V8
You can cut the diff or remove the bracket completely from the beam and fabricate another one, I did the later but have no pics, the diff casting is also a bit bigger near the front and will need clearance added.
Old 02-09-2018 | 06:41 PM
  #62
daiboy370's Avatar
daiboy370
[img]blob:https://passionford.com/d0ce1814-32a2-4f76-8f42-478559cc7e21[/img]
Old 02-09-2018 | 08:49 PM
  #63
Marc sierra
[QUOTE=janus;6779409 Is it just the 2.9 4x4? Not sure but I thought the Scorpio Mk1 ("Granada Mk3") also came with other 4x4 engines and I would guess they are all using the 7" rear diff.
[/QUOTE]
There was also a 2.8 4x4, before the 2.9 was introduced. But there were no Granada mk3 4x4s other than those.
Old 02-09-2018 | 08:51 PM
  #64
daiboy370's Avatar
daiboy370
[img]blob:https://passionford.com/4ead1706-da19-461b-ab60-15ce76f71143[/img]
Old 03-09-2018 | 08:24 AM
  #65
daiboy370's Avatar
daiboy370
thanks very much for your guidance, not decided which way to go yet but at least I know it’s possible.
Not it sure why people thing you can’t get the sort of power I’m quoting from the Essex V6, Rick Wood takes them up to 400 bhp, I did post his web page infor that explains this far better than I could, never mind I know what power I have and just need to sort this gearbox then, hopefully I’ll have takeoff at the lower and higher levels. Thanks again.
Old 03-09-2018 | 11:47 AM
  #66
janus's Avatar
janus
daiboy, at least for me your blob: image links here are not working so I can't see what you are posting there.
Mark & Marc, thanks for your infos! So for fitting a 7.5" diff into a 7" beam, the way I understand it it's possible by just some trimming to those two mounting sections and the rest fits without problems (no trimming on housing otherwise, same shafts and interfaces etc)?
R4N SS (12-09-2018)
Old 12-09-2018 | 02:09 PM
  #67
R4N SS's Avatar
R4N SS
shafts are different mate - 2wd 108mm and 4x4 100mm
Old 12-09-2018 | 04:01 PM
  #68
daiboy370's Avatar
daiboy370
Thanks very much for all the responses, I managed to get a 7.5” beam for the XR6 so that will sort out my initial problem of fitting my Cosworth Diff to a 7” beam.
Onwards and upwards, not sure why my pics are not showing, will be something I’m doing wrong I suspect.
Old 17-09-2018 | 01:19 PM
  #69
janus's Avatar
janus
oh good point. and one last clarification:
7" with 100mm would typically be any OHC/DOHC Sierra, maybe also V6, and the 4x4 Sierra incl. Cosworth. How about the Granada Mk3/Scorpio Diffs?
7.5" comes in 100mm variant from Granada Mk3/Scorpio and the 108mm for all the 2wd Cosworth Sierras?
Thanks
Old 17-09-2018 | 01:25 PM
  #70
daiboy370's Avatar
daiboy370
Yes that’s all good. I now have a 7.5 Beam and a 2wd Cosworth Diff so I’m not anticipating any issues. I also have drive shafts 108 mm as per the Cosworth. I’ve already got Cosworth breaks on the back. Many thanks for all you guidance.
SUNMASTER
Ford Classics & Vintage
32
03-11-2007 01:45 AM
ukfalcon
Ford Mondeo Including ST
10-05-2007 05:48 PM
ford1
16-03-2007 12:30 PM
Ginge !
16
15-11-2004 12:59 PM
