Sponsored by:
Sponsored by:
mechanics....it wasnt the glow plugs....?
Old 27-11-2017, 04:31 PM
fuzzy
14000+ post superhero
fuzzy's Avatar
Default mechanics....it wasnt the glow plugs....?
how long does your auto bible allow for changing 6 glow plugs on a 2006 Mercedes c320 ?
Old 27-11-2017, 07:30 PM
studabear
studabear's Avatar
Remove and install is listed as 1.10 hours. That's from a popular data supplier.
fuzzy (27-11-2017)
Old 27-11-2017, 10:07 PM
fuzzy
fuzzy's Avatar
that's not much, I think ill get a garage to do it rather than fanny about with it myself.
Old 28-11-2017, 03:08 PM
tony66
tony66's Avatar
Default garage
easy to break on these-would go to an indy who knows them
Old 28-11-2017, 05:04 PM
fuzzy
fuzzy's Avatar
on this engine all 6 are along the top under the air induction ducts. even if one snapped it surely wouldn't be to difficult to drill down into it and use a nut or stud extractor bit to remove ? especially if its a garage with all the gear to hand. local garage is quoting me £100 to fit all 6 as long as none snap. ill start spraying release oil into them to soak in as it goes in on Monday.
Old 28-11-2017, 07:10 PM
tony66
tony66's Avatar
Default plugs
as mentioned it helps if car is as hot as poss too...good luck!
Old 05-12-2017, 06:01 PM
fuzzy
fuzzy's Avatar
ok the plugs have been changed but its still doing the same. whats the next step to look at? the glow plug light comes on and goes of almost instantly , the car takes about 10 seconds to turn over before starting when the glow plug light comes back on for about 3 or 4 minutes before going out again. its worse in colder weather, turning over for longer but after the first start of the day itll start all day first turn of the key?
Old 05-12-2017, 06:03 PM
timster
timster's Avatar
Fuel filter?
Old 05-12-2017, 06:11 PM
fuzzy
fuzzy's Avatar
i was thinking fuel starvation issue with it taking longer to feed back through the system after a long park up (8 hours + ish)but it was the fact its worse as its colder and it was showing a generic p0670 glow plug circuit code?
Old 05-12-2017, 06:23 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
I had poor starting on my 1.9 tdi golf. First thing in the morning it was a fucker to start after that was fine all day. Then it got to the point wear it would start and run for about 2-5 minutes and cut out then take ages to start like it was air locked. Mine was no1 injector
Old 05-12-2017, 06:32 PM
s1cosse
S1cosse
s1cosse's Avatar
If it's the v6 engine I have done quite a few glow plug modules in the past.mercedes recommend replacing module when fitting new plug.
Have you test for power to each glow plug if 1 is missing a live then the module is at fault.
Old 05-12-2017, 06:48 PM
tay14
tay14's Avatar
Glow plug realy?
Old 05-12-2017, 06:53 PM
slammedorion
slammedorion's Avatar
As said in your previous thread... I changed everything on my Vectra Cdti to cure poor first start in the morning
The cure was a brand new starter motor
Wasn’t cranking fast enough, until the ecu sees the right fuel pressure it won’t allow it to fire
Unfortunately guessing will cost you...
Old 05-12-2017, 07:17 PM
fuzzy
fuzzy's Avatar
it is the 3.0 v6. where is the module situated within the car?
Old 05-12-2017, 07:18 PM
fuzzy
fuzzy's Avatar
could a weak battery also cause the slow cranking?
Old 05-12-2017, 07:44 PM
Adam-M
Adam-M's Avatar
I put a brand new starter on my civic the other day and it made some difference to how quick the engine turned over
Old 05-12-2017, 07:53 PM
fuzzy
fuzzy's Avatar
ill look at the cheapest options first as in fuel filters but the starter motor and control module are about £150 each which isn't to bad.
Old 05-12-2017, 08:52 PM
gcfcos
gcfcos's Avatar
Have you got any really decent diesel specialists near you? We have one near me that even main dealers send stuff too they are that good, they have the best reputation on any garage in the whole of dorset, I imagine other areas would have such a place?
gingeRS
gingeRS's Avatar
stick a new battery on it, often the cause of poor starting with diesels
Old 05-12-2017, 09:22 PM
fuzzy
fuzzy's Avatar
ill take the old one out and stick it on a charge first to try as a new battery is over £200.
Old 05-12-2017, 10:08 PM
The Crocodile Hunter
The Crocodile Hunter's Avatar
If you have a glow plug fault and it's not the plugs then it's likely the module or associated wiring?
Old 06-12-2017, 07:22 AM
RichieST
RichieST's Avatar
When it is turning over or when it fires is it quite smokey for a few seconds? If so that would suggest fuel supply is ok. I would check you have power at the plugs when you turn ignition on. If not go for the module.
Old 06-12-2017, 05:54 PM
s1cosse
S1cosse
s1cosse's Avatar
It's on the front left side of the engine mate. Never had to do a starter on any v6 engine. If you get it on a mb star tester you find the code you have will point to the module mate.
Old 06-12-2017, 06:28 PM
s1cosse
S1cosse
s1cosse's Avatar
There you go mate
fuzzy (06-12-2017)
Old 06-12-2017, 06:36 PM
fuzzy
fuzzy's Avatar
when it fires up theres a cloud of smoke but none when its running.
Old 06-12-2017, 06:39 PM
fuzzy
fuzzy's Avatar
thanks, looks like it should be an easy thing to fit. I don't have any fancy testing gear, it was my mates basic code reader/delete that threw up the p0670 code for glow plug circuit.
Old 06-12-2017, 06:42 PM
fuzzy
fuzzy's Avatar
is this the module? its listed as a relay and its 239 quid but 160 using a discount code?
https://www.eurocarparts.com/basket
Old 06-12-2017, 07:04 PM
fuzzy
fuzzy's Avatar
There you go mate
is that from a 2006 3.0 model? doesn't look the same?
Old 06-12-2017, 09:15 PM
s1cosse
S1cosse
s1cosse's Avatar
You have pm mate
fuzzy (07-12-2017)
Old 07-12-2017, 06:01 PM
fuzzy
fuzzy's Avatar
phoned Mercedes main dealer for the part price....ECP want £239....Mercedes genuine part from dealer is £114...
Old 07-12-2017, 08:11 PM
s1cosse
S1cosse
s1cosse's Avatar
That's about write for Euro !
Old 07-12-2017, 08:47 PM
fuzzy
fuzzy's Avatar
that's 3 times ive went to the main dealer and been surprised by how cheap they are compared to a motor factors ! a reconditioned brake caliper on exchange for my A210 Evolution was £170 , a brand new one from Mercedes was £120. an exhaust from the cat back on that same car that's listed on mercs computer as an AMG sedan was £98 delivered from Germany !
Old 09-12-2017, 03:51 PM
fuzzy
fuzzy's Avatar
glowplug output stage.....is that the control module?
Old 09-12-2017, 06:24 PM
s1cosse
S1cosse
s1cosse's Avatar
Yes mate that's it
fuzzy (10-12-2017)
Old 09-12-2017, 06:50 PM
fuzzy
fuzzy's Avatar
thanks, just making sure the terminologies right!
Old 10-12-2017, 03:56 PM
turnover
turnover's Avatar
On Mercedes the symptoms your saying is usually the relay control module changed 2 in the last few years and has fixed the problem
fuzzy (10-12-2017)
Old 10-12-2017, 04:38 PM
fuzzy
fuzzy's Avatar
i needed it sorted today so I went and bought the beru part from ecp since it was 35% off weekend so got it for £155. the glow plug light still goes off in about a second but it doesn't come back on when it starts. ive also removed the battery to stick on charge over night so hopefully tomorrows very cold morning wont be a problem start !
took about 5 minutes turning over this morning to start but it eventually fired up in big cloud of diesel smoke.
but it still starts though.
Old 11-12-2017, 08:02 AM
fuzzy
fuzzy's Avatar
-6 and it started first turn of the key, problem solved.... Would your Ford still start in - 6 with a broken control module.....?
Old 11-12-2017, 09:19 AM
Adam-M
Adam-M's Avatar
Dont get Glenn started fuzzy
Old 11-12-2017, 10:23 AM
RichieST
RichieST's Avatar
What you on about, Fords don't break
