help with ..wilwood calipers,,,leaking
hi all, just trying to find out why my brand new wilwood calipers leak, ive had some hoses made by rally design and thay leak at both connections ,now i dont think its anythink to do with thw wilwoods , iv rang rally design and thay said its ok to put ptfe tape around them is it ok to put pluming tape around them or will the brake fluid rot the tape any advise, the car is a 1997 escort 1.8 si
thanks
andzz
thanks
andzz
DONT USE PTFE TAPE
No way should you ever have to use PTFE thread tape on any brake connections What type of connections are they? Brake fittings seal on either copper crush washers or seats on the end of the pipe/fitting
I work for Goodridge by the way
willwoods have a tappered thread (1/8 NPT) into the caliper. your original brakes would have been M10x1 metric. make sure you have the correct fitting's/adapters
Also make sure you have the correct male/female connections matching on the nozzles of the pipe. i've seen them mismatch before causing leaks
I've had my wilwoods leak b4 when new however that was a from the crossover form one set of pistons to the other. was just a case of nipping up the 4 main bolts holding both sides together
Originally Posted by D19 STE
Is there a tapered seat at the bottom of the thread in the caliper (the seat should be same angle as on the fitting that srews into the caliper)
I'm not familiar with wilwoods but if its the way i think it is that copper washer on the caliper is doing fook all
looking at the pic the fitting setup is wrong , from the wilwood should be a double male , 1/8thnpt into the caliper then whatever thread you choose onto the other side of the double male - usually m10x1.0 iirc , then the brake line should fit straight onto this with no other joints washers nuts nor fook all , the outer end of the double male should be up against the olive in the brakeline and thats it - i make and have made all my lines for years - and they dont leak - ever
mine were leaking, had a bit of wear tho, 4-pots, just bought new ones and flogged the shagged ones (for repair) on e-bay for £80, sum guy with a Nova who was a bit handy had 'em, he was gonna use it for tracking
brake line is fitted the wrong way round the union into the caliper is wrong
mark you are bang on ive just fitted mine and what you say is what i got from rally design
Sorry I know Morto so its not a double post
That was the line rally design sent after it was quoted one was needed for a 1997 escort si with the wilwood midilite 4pot kit, the connector on the braided hose was not tapered but this one was
Does this mean that the adapter that was in the box should have been used ? the taper end into the caliper and the braided hose should have been a female connector that goes onto the adapter
Originally Posted by alan rainbow
on the hose the male end goes to brake line the female end goes on to adapter at caliper
