6 degrees rear beam and MT Motorsport
MK Motorsport make them and he often has them in stock. You can get them to take a Supra diff if you want and also lugs to take his bladed anti roll bar if you want it.
07753 440 553
07753 440 553
I have been wrong before but doesn't MK make them for MT anyway?
Caddyshack (20-09-2017)
His work is the best no doubt about it
MK is good but dont expect to receive the beam in the same year you ordered it.
i would talk to SCS unless MK can give you a promised date of delivery your happy with.
cheers si
cheers si
Mark from mt is one of the best guys I've ever dealt with. I know he's been really busy lately but unlike him not to respond. I've pmd you his mobile number and if he doesn't answer leave him a voicemail.
Give scs a ring mate
Cheers Paul
Cheers Paul
I don't think his beam is in the same league but is a lot cheaper.
Those ones seem good value at Ł800, but guess they are fairly unknown/ proven?
Do people find the ride much harsher on rose joints vs bushes?
They are and also they retain all the brackets and fixing that are required for use in a road car. I have seen most of it chopped off the more expensive beams. No fitment problems at all.
The only item i have changed is to add rubber boots to the rose joint to keep the crap out. Mine also has mounts to adjust the ARB location for some adjustment.
Have you noticed how many threads we get with all this advice and yet the OP doesn't even reply?
If anyone is using a rose jointed beam on the road the joint need to have the boots fitted as it is now an mot fail.
I've not had any problem with joints fitted with boots but have had fail/worn out ones that were just open. They don't like grit and dirt in them there are side seals for the joints but I don't think they will work as well, but I've not used them before.
My car is rose jointed all round with no boots and it passed the MOT 2 weeks ago. I guess you need to have a nice MOT tester?
Where's best to buy rose joint boots?
Adam-M (25-09-2017)
