Ford Sierra Alternator Problem
So my car isn't charging the battery at all! I am just after converting the car from a 1.8 to a 2.0 DOHC EFI the engine had been sitting for 8 or so years as had the alternator.Is there anything else other than the alternator not working that could be causing the problem? There is only two connections on the alternator aswell a thick red wire and a very thin black and blue wire there is room for another connection but there doesn't seem to be a wire anywhere? Also if it is the alternator is there anyway to revive it?
I haven't had time to put the dash in or cluster so im not sure! Could i just bypass the connect and put a wire on it to check for myself?
Ohh ok! I hadn't thought about that i just thought that would be taking the voltage reading! I'll get that together so and try it again! Thank you!
