Cosworth sump gasket advice
I have been searching but I still can't find a definate answer on how to successfully do these. I have a 200 block with 2WD sump, bother surfaces are clean and I'll be using a cometic gasket with genuine half moons, can someone give me their advice on doing these based on previous experience, do I sealed? Should I locktite the bolts when doing?
as above the cometic gasket is good i used one on my sump use a smear of good instant gasket on both sides of the half moons take your time they can be tricky no sealant on sump gasket dont use lock tight on the bolts clean all the bolts proper and bolt holes and torque them
