Cosworth YB 500 BHP compression
#41
cossie fan (unluckerly)
#42
Kool mate
#44
So less cylinder pressure and less heat with a lower comp engine?
Mark seems to run high boost figures on a majority of his engines though and a lot em are specced at around a standard compression ratio?
Cheers Paul
Cheers Paul
#47
Surely if you drop the compression just to achieve the power then you end up with a laggy and lazy engine? There are very few instances where it is all about peak numbers, it is how it behaves on the way to the headline figure, unless you are building a full on drag car.
I think that if you really want 700bhp then you have to be prepared to spend big, like cossy Dave has, engine fails...build it stronger with alloy block and arrow crank....if you plan to do it without the big budget then it could fail and when it does you end up spending more as you have the first build cost and then then the proper build cost.
#48
Sponsor
This subject is actually a real arse as some tuners say you can't achieve big power on standard comp ect ect yet Mark has been using high comp on all his builds for few years and Julian Godfrey has run 10.1 on 700 bhp + engines with 2 bar antilag which are driven absolutely flat out so this low comp argument is very much like the world is flat lol
#49
**RS COSWORTH**
If your planning on fitting a twin scroll in the further then go for standard comp going low comp engine will not be suitable for twin scroll if you go that route in the further.
Best to see if you can get a ride out in different setup cars to make your mind up.
#50
And if so why?
I've heard people mention this before
Cheers Paul
#51
As mentioned previously less heat and pressure in the cylinders??
Cheers Paul
#52
The higher the compression the more responsive the engine tends to be, in an ideal world we would run the highest possible, but we lose it to prevent detonation. I think people drop it to allow more boost higher up
Dropping to gain more reliability than more power is actually the same thing, it is a trade off, more power OR more reliability.
#53
Isn't there more scope for ignition advance on low comp engines to compensate for that though?
Do you mean more boost held at high revs?
As opposed to dropping off as revs increase?
Cheers Paul
Cheers Paul
#54
Happily retired
RUBY123 (05-02-2017)
#56
#59
So how much ignition you can use does come into play depending on comp ratio?
Cheers Paul
Cheers Paul
#62
It's a window of knowing how it all will work and how much power you can keep in it when the intake heats up.
Mark
#63
So would a regular comp engine with medium ignition advance drive better/have more power than a lower comp engine with more ignition?
(If both had same turbo, inlet, cams, etc?)
Cheers Paul
Cheers Paul
#64
Mark
turbotrev (04-02-2017)
#65
Gotcha, thanks
Cheers Paul
Cheers Paul
#66
Sponsor
Turbo and cam choice are a massive influence to like t4 for instance is a very laggy turbo and if most tuners are honest they will tell you surge is a massive issue along with the gt range so imo you are recruiting not only your power through the rev range but response to due to heavily managed boost curve so it's not just about raising the comp imo
#67
Dick Johnston ran one of his 550 plus bhp engines on a dyno without the turbo strapped on, it made 80 bhp! back then I believe they were down to 6.7 to 1 compression with the basic old ecu they had 30 years ago so you are spot on, think how much more responsive those beasts would have been with todays technology running far higher compression but the same boost.
#69
I seen a video of him saying that, I'm sure it made 680hp with the turbo connected and 80 without lol
Bart (04-02-2017)
#71
Anyone can make the power...and anyone can do it easily on race fuels.
But nobody is making 750hp on a 2.0 on pump fuel at over 10.0:1 CR unless it's pulling over say 10krpm
#72
At or over 10:1 CR ?
nope.
Again, look at the specific comment I was quoting. There is nothing difficult about making 5, 6, 700hp etc but the comment was specifically at Jay's comment about Julian Godfrey making 750hp at 10:1 CR
Very easy with the right fuel.
nope.
#73
I think we are hanging on to the 10.0:1 here, jay is just saying that you don't need to drop from standard on a 500 bhp car, we are not trying to build a 10:1 700 bhp car.
We all understand that if you want to build a 700 bhp plus engine with big boost you are not going to start with higher than normal comp ratio.
#74
Sponsor
Lol toby you correct arrogance seems to have a wide band on this forum and also not listening. My point was that the average person and some tuners say and believe that at 500 -600 you need to go lower comp than standard to achieve this which is bollocks and Mark and dave have stated 700 bhp at 8 5 on pump an yes at 10.1 race fuel and higher revs do the job but that's comon sense lol
#75
likewise for a 500hp car you could very easily go higher even on pump fuel.
All that nonsense in the past about mega low CR's was always insane.....although for the touring car side of things could perhaps be slightly justified given they ran very long races and low rpm performance was never even a consideration.
Although pretty sure they blew up often even back then ? lol
#76
Mark
#78
He used the motronic ecu from the RS200 program and managed to crack the code on them before anyone else but it was still a pretty basic set up.
Mark etc are far better placed than me to confirm why they had to run such low compression back then, down to det I believe.
They all ran special brews to a degree, remember the story about Brodie storing toleune in the roll cage tubes of his and adding it to the fuel during the race!
#80
Whether the RS500 touring cars could have run better with todays technology is not important to me. At the time they made for very exciting racing and were at the top of that periods tuning level.
This thread has turned into a low comp v high comp argument. If the guys who are running low comp big power engines are happy and the guys who are running high comp engines are also happy does it really matter?
Budgets are also important to a lot of people, everyone would love a 700bhp road going Cossy but not many can afford it.
turbotrev (06-02-2017)
