ST24 lost power....................
its gone flat as a fart!! Any ideas?? Just doesnt want to pull at all. lost 20mph top end too.
It used to redline in every gear, but the revs rise real slow now, it a right pain in the arse, feels like I've got the handbrake on!
Misfire, check leads/plugs and renew. This happened to me on my old sierra, turned out as I wwent round a roundabout one of the HT leads came out and was only running on 3 cylinders well 5 in your case
good luck
good luck
Common problem is the secondary valves, underneath the cover on the front bank of cylinders is a control unit, unless its an early unit where its vacuum controled..
Either the unit is playing up or your butterflies in the twin tract manifold are sticking.
Go over to www.fordmondeo.org and do a search for secondaries and you will see what i'm on about.
You can clean the secondaries (butterfly valves) and try that but if the unit aint working it may need replacing, check to see if its pulling the cable ok.
Mine had an intermitent fault with this but this was down to the control unit i was on about.
Good luck
Mike
Good luck
Mike
When my old one went like that it was the internals of the catalytic converter had come loose and where severely restricting the exhaust. apparently its quite common on all mondeos
Cheers lads, I'll have to inspect tommorow. There is a slight rattle that clears after about 3.5k revs, so perhaps it could be the CAT breakin up.
I agree with SIB, on one of the 5 mondeo v6 2.5's we have had in the family the bush went in the linkage for the secondary throttles. I have also had the problem that the secondary throttle control box failed and needed relacing ( Neil_s off this bb changed his just the other day ) I have also seen the cats breakdown and get sucked into the inlet manifold an ruin the entire engine aswell.
I'd check the secondary throttles, If you get someone to rev it from a standstill when it goes past 3.5 under full load you should see the secondary throttle linkage working. its located under the main throttle body
Good luck
RW
Good luck
RW
Finally got chance to have a look today! The throttle cable for the secondries had snapped. Manage a bit of a bodge repair untill I've got chance to replace the cable, feels soooo much better now!
Had to take the control box to bits to sort the cable out, does anyone know if the arrangement of cogs sorts itself out?? because the one at the end that turns the plastic which pulls the cable could be put back in many diffent positions. I left mine as far as it would go without any force. Seems to work ok! LOL
Cheers.
Cheers.
The Youth.
30-09-2015 09:59 PM
deathrider666
28-09-2015 06:12 PM
