Ford Diagnostics
Old Apr 9, 2005 | 02:22 PM
Fozy's Avatar
Fozy
Default Ford Diagnostics
Anyone know what a dealer charges to put the car on diagnostics?
My car isn't running too healty after i've replaced the headgasket.
car is running standard engine wise.
Old Apr 9, 2005 | 02:55 PM
Billabong's Avatar
Billabong
What car and did you find out why the hg went in the first place?
Old Apr 9, 2005 | 05:31 PM
Fozy's Avatar
Fozy
escos big turbo. uprated it for future power upgrades. nowt was wrong with the car
Old Apr 9, 2005 | 05:48 PM
DOO's Avatar
DOO
£70 to £100 an hour most dealers charge
Old Apr 10, 2005 | 01:08 AM
Stu @ M Developments's Avatar
PassionFords Creator
I would charge £45+vat
Old Apr 10, 2005 | 09:54 AM
Fozy's Avatar
Fozy
now that is good stu, but i can't get to blackpool with it. Wish i never took the thing apart now
Old Apr 10, 2005 | 10:07 AM
Graceland's Avatar
Graceland
Team HOTHOT!
you et the cam timing and distributor timing all set properly when you put the cambelt back on?
Old Apr 10, 2005 | 11:13 AM
Fozy's Avatar
Fozy
timed it as per the ford manual
Old Apr 10, 2005 | 12:10 PM
Graceland's Avatar
Graceland
Team HOTHOT!
how have you lined up the TDC marker on the crank pully?
Old Apr 10, 2005 | 01:09 PM
Good line of questioning here Paul
Also check you havent mixed up the knock and phase plugs, or TDC and knock plugs. Ive seen it done once or twice.
Blue CTS plug at rear passenger side oh head?
Finally, did you break stub off map sensor when you lifted head? check it.
Old Apr 10, 2005 | 01:14 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i learn from the best stu
also i learn from my own mistakes
Old Apr 10, 2005 | 01:28 PM
GARETH T's Avatar
GARETH T
caught me out once,, when i got called on a friends car after he had replaced the head gasket but got there in the end
Old Apr 11, 2005 | 04:30 PM
Fozy's Avatar
Fozy
Everything was put back together correctly. I had a loose wire in the Multiplug by the coil. Hardly noticeable but luckily fell out when i checked the wiring. Clipped back in and running sweet
Thanks for the advice guys This forum is the best!
Old Apr 11, 2005 | 04:50 PM
Graceland's Avatar
Graceland
Team HOTHOT!
good stuff m8y
Old Apr 11, 2005 | 04:52 PM
dvid's Avatar
dvid
I paid £25+ VAT from Ford.... but not an escos
Billy_RS
16
Oct 11, 2025 09:41 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
borboyous
Aug 22, 2015 11:17 AM
41
Aug 21, 2015 06:47 AM
