alloy wheel repair....
Old 06-10-2016 | 10:29 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
Default alloy wheel repair....
one of my alloys has been repaired previously with a 25-30mm crack on the inside rim but it seems to be slowly leaking air.
someones told me if its been welded once it cant be welded again. is this true? or can I send it somewhere to be repaired properly?
Old 07-10-2016 | 09:23 AM
jonfoc's Avatar
jonfoc
I can't see why it can't be welded again. Grind it out til clean then do it properly
Old 07-10-2016 | 09:41 AM
Adam-M's Avatar
Adam-M
Drill a small hole at the end of the crack so it won't continue then fill it up with weld
Old 07-10-2016 | 09:48 AM
fuzzy's Avatar
fuzzy
Ive spoken to another wheel repairer this morning , he said if there's extra metal on top of the original repair its been mig welded, thoeyll grind that away and drill the hole at the end of the crack and tig weld it and itll be fine.
Old 07-10-2016 | 10:17 AM
Supercharge6's Avatar
Supercharge6
Boosting
See if you can get them to do this on both sides of the surface area where the crack is. Hub facing and tyre facing. Less chance you'll need a future repair...
Old 07-10-2016 | 11:41 AM
Adam-M's Avatar
Adam-M
Never heard of mig welding alloy before?
Old 07-10-2016 | 06:08 PM
big_wasa's Avatar
big_wasa
Yeh things like tipper lorry bodies are miged.
Old 07-10-2016 | 06:09 PM
stevieturbo's Avatar
stevieturbo
C**t
Very common, just depends where you look.
For mass produced items in industry TIG would be far too costly and slow, unless it really was very critical items.
The main issue with it is getting the soft wire up the torch, so often a spool gun is needed instead of a regular torch.
costina
Alloy wheels and ICE for sale
07-10-2016 05:51 PM
parrot
12-09-2016 06:13 PM
jdsjojo
10-09-2016 09:44 PM
bridgeman
Ford Fiesta
06-09-2016 10:38 AM
dirtysteve
26-08-2016 09:37 PM
