carbs and zetec and mot
hi guys the last car i built was a turbo powered focus which is now long gone, but i am now building a mk5/6 02-08 fiesta and im going to put a 2.0 zetec on bike carbs running nodiz etc, will be doing a wiretuck and removing abs, airbag and full engine loom ecu etc so will be a bare except lights loom
the only issues im not sure about is mot time, because itll be running carbs (im going to have a cat and decat made)
but what are the legalities regarding carbs for mot time ??, obviously dvla will be notified about engine swap etc
im using zetec as if it goes bang ill scrap it and use another where as the duratecs are apparently quite weak on bottom ends and are still pricy
also has anyone done a mk5/6 engine conversion ??
If the vehicle has had an engine conversion from an older vehicle and it can be proved from which vehicle it came from then the emissions are tested from the age of the transplanted engine. I found this when I motd a Vauxhall frontera which had an old red top 16v from an Astra gte fitted. I tested it as if it were an e reg Astra gte
It will need to have a cat fitted, it will need to meet 0.30 CO or less fast idle 200ppm HC at fast idle lambda between 0.97-1.03 and from memory 0.50 CO at idle.
(Can't ever remember a zetec that didn't have a cat.)
Other wise its gonna be a dodgy mot.
Passionford Addict
Anyway my point is there was zetecs without the cat
Just get an mot friendly map for the mot
No car requires a Cat to Skoda2010, even a brand new one
It just has to Pass the relevant test.......
A cat missing that was fitted from the factory is a reason for rejection though. Don't let me convince you though, I've only been doing mot's for 16 years.
And an MOT friendly map for a carb equipped car that legally is supposed to have a cat and pass a cat based MOT ? lol.
Done it many times. Carb kits with mappable ignition used to be fairly common, certainly in the kit car world, Webber alpha gold on a zetec fittment for example. The car only has to Pass the emissions test relevant to its age.
And is quite clear in this case....this vehicle needs a cat to pass any legit MOT.
You can map ignition, and that tiny print by gfcos only mentions passing the right emissions test. I've never seen anything stating any car needs the cat fitted. I haven't taken a car without one for a test since 2011 but don't think anything has changed since then.
To add to that, it's a struggle and I don't think the op will get through a test.
However there are plenty of carbed zetecs running round with mots and no cat, they can't all be bent, and mine wasn't.
I still haven't seen anything telling us that a cat needs fitting either
Oh and Construction and Use only requires you to Pass the relevant roadside emissions test also
I have checked the latest testers manual https://www.gov.uk/government/public...and-7-vehicles
It appears to have changed since I last presented such a vehicle ( decatted but able to pass the test ) There is now a visual check 7.1.3 which is new, you can see the black lines saying so, so yes it should be failed ( god knows why if it passes the test )
However this is not supported by this https://www.gov.uk/government/upload...th-edition.pdf
Which makes no mention of actually having to have the cat fitted where one is expected, just having to pass the test, as it used to be.
That is the case now so it seems, see my post above this one, but it hasn't always been the case, this has changed since 2011?
It is a legal requirement since 1992 ( age appropriate vehicles of course )....and that hasnt changed.
And again, construction and use regs dictate it.
And just because a car as an MOT cert...means sweet FA, even more so over there. I've bought cars before with fresh MOT's, that wouldnt have a hope in hell of passing any legit MOT.
Nothing regarding the legal requirement for a cat to be fitted has changed for at least a decade....or much much longer.
The other document I provided is the basis for C&U and there is also no mention of visual confirmation of fittment in that, only the test the car must Pass.
I'll stand corrected on C&U if anyone can be bothered to show the document and quote the relevant section like I have proved with the MOT links above
What a waste of a good engine
Depends on the kit car and what donor it was built from...and what the new vehicle is deemed to be.
If all new, then it would need to pass the relevant IVA and pass all emissions test and be fitted with age appropriate emissions gear.
Afterwards...many probably get a dodgy MOT same as everyone else it seems from this thread
Russ Payne
09-03-2016 07:12 AM
CarlRsT
10-11-2003 05:03 PM
