worrying wobble :-(
Old Apr 7, 2005 | 09:33 PM
cozzymatt's Avatar
cozzymatt
Default worrying wobble :-(
i have had this annoying wobble for a while now.. when pulling off it is fine and also when driving slow it is fine but when you put the car under load there is a wobbling coming from the centre of the car !
I ahve had a look round underneath and everything looks ok the only thing i noticed was there is a bit of play in the front prop and also play in the carrier for the rear prop ( think its called a carrier ! ).
should this play be there and what could cause the wobble if this is not it ??
please help because this is driving me mad... its not a pleasure to drive when its like this
the car is a '95 small turbo escos..
Thanks
Matt...
Old Apr 7, 2005 | 09:36 PM
SPADGE's Avatar
SPADGE
If the front prop has play in it replace it now or it will do a lot of damage to your wallett!
Old Apr 7, 2005 | 09:40 PM
cozzymatt's Avatar
cozzymatt
its not actually play in the prop but looks as if it is in the transfer box! where the front prop goes in! if that is the transfer box on the tail of the gearbox ?
Old Apr 7, 2005 | 09:42 PM
Physio's Avatar
Physio
Default Re: worrying wobble :-(
[quote="cozzymatt"]i have had this annoying wobble for a while now [quote]
Do you find it only happens if you've had a drink?
Sorry mate - have you checked all the bushes etc?
Old Apr 7, 2005 | 09:44 PM
SPADGE's Avatar
SPADGE
Ahh ok can you elaborate on what this wobble feels like then? If it is more of a noise then a physical wobble then the front prop could be catching the exhaust or the drop gear chain could be fooked!
Old Apr 7, 2005 | 09:48 PM
cozzymatt's Avatar
cozzymatt
ok its not the exhaust !!if i wrap my hand around the front prop and twist it there is a lot of play and it seems like you can hear internal noises when you twist it back and forth... all the bushes are new, i have recently put a vibratechnics gearbox mount on the car and it seems like it has made it worse !! i think its because the rubber is not taking the wobble ! the car is
i know its gonna be something expensive i would just like to know what
Old Apr 7, 2005 | 09:49 PM
SPADGE's Avatar
SPADGE
My favourite is still the chain for the drop gears being fooked and slapping around under load then!
Old Apr 7, 2005 | 09:52 PM
cozzymatt's Avatar
cozzymatt
but would this make it feel like a wobbling ? common sense would say propshaft but this feels ok as i said but there is play in the carrier between the box and the rear diff ! should there be ?
Old Apr 7, 2005 | 09:57 PM
SPADGE's Avatar
SPADGE
The reason i am suggesting this as a possible problem is that i had the same (from your description of it) 'wobbling' sensation in my 4x4 once and this turned out to be the reason. Your best bet is to call Berni the gearbox man see if he can shed any light on it. His number etc..are in his banner ad at the top of this page or go to www.gearboxman.co.uk
Old Apr 7, 2005 | 09:59 PM
cozzymatt's Avatar
cozzymatt
i had a recon box from Ford about 6 months ago would this be part of the box or is it seperate ?
Old Apr 7, 2005 | 10:10 PM
cozzymatt's Avatar
cozzymatt
Old Apr 9, 2005 | 04:01 PM
Damo V's Avatar
Damo V
have a look at the prop (BOTH) UJ's, use a good lamp spin em round, look for signs of rust staining, if the front prop uj is failing (common) it will show rust and the rust will run out the uj when it gets wet if you get me,
when you twisted it as described above, what you need to be sure of is that the uj moves as the prp does.. if there is play thats the problem, the rattle noise when you rock it back and forth is usual mate (though not excessive)
Oranoco
41
Feb 11, 2016 01:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Mark Mawson
Aug 31, 2015 07:09 PM
Alloy wheels and ICE for sale
Aug 16, 2015 07:55 AM
