SPA boost/temp gauge
Old 06-04-2005, 02:33 PM
Westy
Westy's Avatar
Default SPA boost/temp gauge
just got hold of one, and wondered how accurate it will be?
elec one
bought 2nd, so anyone have instructions or know how its fitted please
Old 06-04-2005, 02:36 PM
Philly
Philly's Avatar
I have one of these!
Unfortunatly I dont find the boost pressure that easy to read especially when its blinking up and down with .1 psi incriments!
Water Temp and Fuel Pressure one is pretty useful though!
Old 06-04-2005, 02:39 PM
Philly
Philly's Avatar
There should be a complete wiring loom with the gauge, if you have that then it should be very simple to wire up.
Just Black for Earth, Red with inline fuse in it for 12v. then there is a button which you have to mount seperately from the gauge. Only other parts are the plugs on the other end for the sensors.
Old 06-04-2005, 02:41 PM
Westy
Westy's Avatar
was it easy to fit mate?
where did you mount it? thought the psi would go up like, 4, 5 ect.. not 4.3, 4.4
what water temp is normal when driving?
aorry about the questions
Old 06-04-2005, 02:42 PM
Westy
Westy's Avatar
i see your in essex, not too far away
oddkidd, as in Jano?
Old 06-04-2005, 02:47 PM
Philly
Philly's Avatar
Yeah, easy as pie mate.
Yeah not far from there dude!
Old 06-04-2005, 02:49 PM
Philly
Philly's Avatar
Normal Water Temp while say @ 50 mph, and temps outside of 20 C. Mine used to run about 80-85 C.
I mounted three of them where the heater vents used to be in one of those fibre glass things you get at the shows!
Old 06-04-2005, 02:51 PM
Westy
Westy's Avatar
any pics of yours installed mate..
Old 06-04-2005, 03:19 PM
Philly
Philly's Avatar
Have at home, I gotta load all of pics up yet, its a pain in the jacksy!!!
Sorry mate, will get load of pics up soon!
Old 06-04-2005, 03:21 PM
Westy
Westy's Avatar
cheers mate
im crap at things like this so pics of where all the bits go would be good, got all the loom and sensors
Old 06-04-2005, 03:24 PM
marco polo
marco polo's Avatar
westy
here are mine in my 3dr
cheers marco
Old 06-04-2005, 03:33 PM
Philly
Philly's Avatar
Cool, there ya go Westy!!
Looks Phat Marco
Old 06-04-2005, 03:38 PM
Westy
Westy's Avatar
nice MArco.. might have to get some more now
what do the lights do?
also, those red button things near the gauges, whats the crack?
Old 06-04-2005, 03:39 PM
rsnissan
rsnissan's Avatar
bloddy hell marco thats excatly how i was going to install mine
At least i know it looks good
Old 06-04-2005, 03:56 PM
essexrsturbo
essexrsturbo's Avatar
i aint a fan of digital boost pressure guages as there hard to read due to how quick they change, only things ya can read are boost held and vacuum, the digital act guage is the bollox though
Ryan
Ryan's Avatar
the "red things" are buttons to switch between green and red backlit i think.
Old 06-04-2005, 04:04 PM
essexrsturbo
aint they just turn em on? i thought red and green back lights were seperate guages
Old 06-04-2005, 04:06 PM
marco polo
marco polo's Avatar
The buttons set all the gauges they even do hi and low voltage hi and low warnings eg: hi and low temp or pressure
you can even change the back ground colour red/green theres load of other fuctions that these gauges can do they are every good , they even got peak recall of boost /charge air /oil temp /oil pressure/water temp /fuel pressure
if you look at the gauges carefully the have 2 lights 1 on the top and 1 on the bottom that light up yellow and red you can use these to set your max psior temp or what ever then if you go over or below that reading that you have set these will then light up to let you know
Andy
they have been in the car for about 2.5 yrs now
marco
Old 06-04-2005, 04:09 PM
rsnissan
rsnissan's Avatar
there for all the features you have peek recall and also you can set the lights to come on the gauge at pre set levels as well as a few other features (saves you needing to stare at the gauges when driving ) you can also use the triggered outputs to run anything with a 12v live for exapmle water injection or water spray or warning lights anything else for that matter
edit marco beat me to it!
they look spot on marco
Old 06-04-2005, 04:10 PM
essexrsturbo
Old 06-04-2005, 04:12 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
im having SPA in my track car, top gauges imo
marco polo, nice set up mate
Old 06-04-2005, 04:13 PM
Westy
Westy's Avatar
didnt realise it had peak recall... clever little gauges
cheers Marco for the details
ps essex, elect are the tits
Old 06-04-2005, 04:42 PM
rapidcossie
rapidcossie's Avatar
i have boost pressure and oil pressure one.
only gauges i would use now.
the manual says they are accurate to 0.001 of a psi while being tested at 232 psi!
guess thats pretty damn acccurate then!
Old 06-04-2005, 06:12 PM
marco polo
marco polo's Avatar
thanks lads no probs
Old 06-04-2005, 06:19 PM
Sean Bicknell
Sean Bicknell's Avatar
The latest SPA's can also be orderd with blue background lighting and they look really swish!!
Old 06-04-2005, 06:30 PM
marco polo
marco polo's Avatar
Sean
i have seen them in blue and they look the b0ll0x
Old 06-04-2005, 06:34 PM
dave cos4x4
dave cos4x4's Avatar
i have one,boost and temp but need the bit that plugs on the end to read the boost.
think its screws into the inlet manifold to read the boost pressure.
Anyone know where i can get one.
thanks.
Dave.
Old 06-04-2005, 06:40 PM
Sean Bicknell
thanks.
Dave.
If its the pressure sender your after, i have a couple of spares and i'd sell one to you. Alternativly you can buy one from SPA
Sean..
Old 06-04-2005, 06:53 PM
dave cos4x4
Sean,
think it is the sender bit,looks like a bit of a plug at the end of the boost wire,pressume they have unplugged the sender and left that in the manifold, if thats how it is wired in.
Sean, tried SPA and get put through and goes onto a message.
if thats what i need,the sender bit,i would buy one off you.
You going to Cental Day,can get it off you there if not will pm you my details.
thanks,
Dave.
Old 06-04-2005, 06:59 PM
Andreas
Andreas's Avatar
Good choice.
Mine...
Ive got a spare Boost/Temp gauge in the garage so if you need any photos just let me know.
Old 06-04-2005, 07:06 PM
DaveEscos
DaveEscos's Avatar
phnaaarrr
you really want defi's
Old 06-04-2005, 07:11 PM
Sean Bicknell
Sean,
thanks,
Dave.
Yeah the plug that goes onto the sender is square with a screw fixing through the middle and contains four wire connectors.
No problem I will bring a sender to central day for you.
Sean..
Old 06-04-2005, 07:34 PM
dave cos4x4
Sean Bicknell,
Sean, thats exactly what i have,the square plug with no sender.
If you could bring it Sean that would be great!
See you there.
thanks.
Dave.
Old 06-04-2005, 07:42 PM
Andy-R
Andy-R's Avatar
Great guages......programmable outputs allow endles options....for example rad fans kick in at given temp on water temp guages.....Gas switches off at given boost preassure....top quality
Old 06-04-2005, 07:54 PM
marco polo
marco polo's Avatar
DaveEscos
nothing wrong with defi's mate they are very good aswell
i think they are one of the best anolog gauges on the market
still the with the SPA you can set them so they can turn things on like water injection/fans/lights you name it .
you can even set them to turn your engine off if you wanted to with a low pressure warning
i bet your Defi can't do that
Old 06-04-2005, 08:41 PM
Westy
Westy's Avatar
right lads, this is the one.... how much are they new?
also this is obviously boost, but temp.. is it water temp? like the idea of fans setting in at a dtermined temperature but only has one button, so is it all set from this? really need some instructions
Now where do these pics go???? im am sooooooo shit at stuff like this ut refuse to pay someone to do it at i want to learn
Old 06-04-2005, 08:53 PM
Porkie
Porkie's Avatar
I've got five of the fookers and haven't got a clue how to set up all the warning lights which are very good... I also don't know how to reset them even though Martin has shown me 3 times
Great gauges actually... you do see the warning lights as well.
Gonna rip this dash set up out and remount all the gauges, switches and fuses and make it look alot more pro
Old 06-04-2005, 09:12 PM
Westy
Westy's Avatar
cheers Porkie, that helped me out big time mate
plus side... that looks the tits mate
Old 06-04-2005, 10:12 PM
Andy-R
Andy-R's Avatar
Westy am sure if you were to call the Guy's at SPA they would sort you out a manual...they are Very very helpfull
The temp can be used for ACT, Water, Oil basicaly whatever you decide
more detail and contact info here...
http://www.spa-uk.co.uk/design/dualgauges.asp
Old 06-04-2005, 10:25 PM
Sean Bicknell
Sean Bicknell,
See you there.
thanks.
Dave.
No worries mate, will do. PM me a day or so before, cus my memory is poo.
Porkie you make me laugh. If your dash is gonna change to look professional the first thing you need to do is STEP AWAY FROM THE CAR!!!
Quick Reply: SPA boost/temp gauge
