Unbranded Radiators
Unbranded Radiators
As you may have read in one of my previous post's my radiator decided to give up on the way to the M.O.T. station.
I am obvioulsy looking to replace it ASAP and have seen on Fleebay unbranded 50mm core chrome radiators ranging from prices £125- £170.
Has anybody purchased and used one and your thoughts on them?
Are they cheap copies?
Have they lasted???
Look forward to your replys.
Have they lasted???
I have one in mine and as a radiator it's ok, but I can't say the same for the fitment.
The problem is they have the 'lip' missing at the top, which would normally bolt up against the standard I/C, which means it can 'pivot' which can result in the PAS pump pulley fouling the top hose.
I did look at the time and all of them are of the same design (probably due to the fact that the majority have larger IC'S anyway, so wouldn't be needed)
I created a thread about this, but had little response, so I guess others did not notice it and/or realise the above problem!
Martin
Martin
escortedal
11-12-2015 11:54 AM
