Best Brakes for 2wd saph
#41
cossie fan (unluckerly)
you are talking about things like lotus's and caterhams etc where they simply don't have the mass capable of applying enough weight to the front wheels when you stamp on the brake pedal
if stoppers the size of dustbin lids are good enough for btcc cars they are good enough for road cars![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
#43
fair play lol must stop well I've been in a 700bhp one with 330's on 6 pots it stopped extremely well as a road car. Track would be different were the brakes are used to there limit for a long period.
#44
As I've alluded to before, bhp has little to do with it.
It's the use and pad selection.
If the pads work from cold, l don't believe your disks can be too big.
Race pad in road car, not so good for the first brake application.
Does my head in all this, for 800 bhp shit, consider the use and spec the components accordingly.
#45
#46
Don't forget some decent pads too as I know sometimes people over look this and just go for the biggest they can fit
Cheers Paul
Cheers Paul
#47
Think I will see what high spec can do with my calipers and see what size disc I can get in them, I really would like 330mm tho. High spec have quoted me £50 per caliper just to inspect? Then 24 pounds a seal kit plus fitting, seems a bit of a piss take to me
Cheers si
#48
How did Breda manage to rotate his rear calipers 90°? It isn't possible to rotate the hub due to the bolt pattern?
![Name: XF9P0995-2.jpg
Size: 97.2 KB](https://passionford.com/forum/attachments/general-car-related-discussion/25080d1501267929-best-brakes-for-2wd-saph-xf9p0995-2.jpg)
#53
xr2mk2turbo
27-11-2015 10:37 AM
4x4kiwi
26-11-2015 02:54 AM
