Best Way To Drop Rear Springs?
Going to be lowering my Focus over Christmas.
Front is easy. Break ball joint, remove strut and swap the spring.
Rear I'm not so sure. I've never changed springs on an independent rear setup before.
In my mind I think if I popped a jack under the rear arm, removed one of the bolts (any preference to side?) and dropped the jack they would come out nicely. Then reverse to pop new ones back in.
Right or wrong? Is there an easier way?
Bailes.
Bailes.
Received 1,044 Likes
On my ST170 i just took the rear shocker nuts, removed the rear link rods then levered the suspension down and slid the spring in.
I dont know if the mk3 will be the same.
That depends. Lowering it may mess it up. That is if the bolts have not seized into the bush sleeve either!
Gazzonator (13-12-2015)
Chas (14-12-2015)
ZetecShearer1987
Ford Focus (All Models)
21-11-2015 10:22 AM
