Quick question with this Pistons
Ha that's the problem I can't remember didn't mark them when I pull them out. I stripped it then took awhile for the rods to turn up.
Ahhhh, that makes more sense! I would go with arrow to front of car by default but have a look to see if the skirts are cut out to avoid a crank counter weight. I can't see any other differences. However the piston pin offset might not be equal, the rod end could be closer to the intake valve or exhaust valve if the offset is not equal.
Rob,
Rob,
Thanks rob we had a quick look at the pin to see if it was offset but we'll have another look. You still have your escort?
Or good glad you didn't sell it. Be good to see it. Took it on a track day at knockhill and suffered from oil surge with having no baffles in sump. Took out the crank and no1 rod (heat damage) manage to drive the 3hr drive home no problem.
I would say the Arrow points to the thrust side of the bore
Standing at the front of the engine the thrust side is on the left.
This is proberbly because the gudgeon pin is offset on a 4x4 piston to stop piston slap when cold.
Cheers tim
Cheers tim
I gest that mate I was only double checking I was right before putting the in and just letting you know it wasn't a yb.
