Map sensor question.
Old Aug 23, 2015 | 09:07 AM
costina's Avatar
costina
Live long and prosper!!
Default Map sensor question.
Really aimed at the tuners.
I was told by webcon that 3 bar map sensors will not be made again and the tooling has been scrapped. And they tested the aftermarket ones and would not sell them.
So what are our options if we still want to retain the weber ecu's ?
I would like a 4 bar sensor as i'm a boost monster😂
Paul
Old Aug 23, 2015 | 09:23 AM
costina's Avatar
costina
Been looking and Julian Godfrey has a 4 bar listed with a adaptor plug.
Guess it would need a remap.
Old Aug 23, 2015 | 12:03 PM
stevieturbo's Avatar
stevieturbo
C**t
Ultimately they all just output a 0-5v signal.
So as long as whoever is mapping it is happy with seeing different numbers, then the map sensor you use is irrelevant as long as it covers the range of pressures you need.
And as said before, looking at the scaling for the Weber 3bar sensor, it's pretty close to a GM 3bar sensor anyway
So again, after checking the mapping, really no reason why they couldnt be used. Although to be fair, most of them seem to come from China now too.
I see a place on ebay.com.au selling a GM style 4 bar map sensor for not bad money
http://www.ebay.co.uk/itm/4-BAR-MAP-...item1e9ab9832a
But there are better quality local options...more expensive too
http://www.jti.uk.com/product/map-sensors/
VW use a 4 bar map sensor on a few of their cars...pretty sure some of them aso have an integrated temp sensor too.
edit, DTA lists part number as 0281 002 316 for the 400kpa sensor
0281 002 456 for the 350kpa sensor
Old Aug 23, 2015 | 02:28 PM
costina's Avatar
costina
Thanks Stevie for the info.😉.
Do you still have the Granada??
Paul
Old Aug 23, 2015 | 04:29 PM
gcfcos's Avatar
gcfcos
I see a motorsport place selling some of there's, is it brands hatch motorsport or something like that?
Old Aug 23, 2015 | 04:37 PM
stevieturbo
C**t
Paul
Always will.
Old Aug 23, 2015 | 04:40 PM
costina's Avatar
costina
They are the cheap copies that webcon will no sell.
Old Aug 23, 2015 | 04:42 PM
costina's Avatar
costina
Originally Posted by stevieturbo
Always will.
Good Man.
Old Aug 23, 2015 | 04:57 PM
jamie956's Avatar
jamie956
Im not sure if they are the cheap Chinese ones, he had a bit on FB about them saying they come from the US and the voltage is correctly scaled for use with weber.
He also sells a adaptor to make a PF01 read as a PF09 if upgrading to a L8.
Not sure how much I trust him had problems with BHP in the past.
Old Aug 23, 2015 | 06:31 PM
costina's Avatar
costina
pf09 and 01 are different so not sure how he has managed to do that. If it was that easy ford would have done it.
Old Aug 23, 2015 | 06:51 PM
stevieturbo
C**t
Ford didnt need to, they had plenty of parts available to choose from lol
Old Aug 23, 2015 | 07:23 PM
costina's Avatar
costina
Very true.
Old Aug 23, 2015 | 07:35 PM
jamie956's Avatar
jamie956
Its a little loom and seams to have a circuit board in line I guess to swap the voltage round. not a bad idea if it works It going to take people coming up with this stuff to keep these cars going.
Old Aug 23, 2015 | 08:03 PM
costina's Avatar
costina
I guess just be nice for these items to be fully tested before someone melts a engine.
Old Aug 23, 2015 | 08:32 PM
turbotrev's Avatar
turbotrev
I just recently went to a 5 bar sensor with an adapter harness.
And had a complete live map too
Cheers Paul
Old Aug 23, 2015 | 08:38 PM
M K's Avatar
M K
Get a sensor from KA sensors
Old Aug 23, 2015 | 10:31 PM
martysmartie's Avatar
martysmartie
The PF01 contains a switch and is open circuit at idle, this is the difference, so not sure how putting a PCB inline changes this.
You can simply invert the wires to change the voltage, which is the done method.
Martin
Old Aug 23, 2015 | 10:54 PM
jamie956's Avatar
jamie956
Martin
Facebook Post
Old Aug 25, 2015 | 06:02 PM
costina's Avatar
costina
Hmmm I am not convinced 😕
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
