IB5 Gearbox oil change.
Recently serviced my car and decided to give the gearbox some fresh oil.
However, since I have done this 1st and 2nd gear have become quite notchy. Pulling the gearstick out of first gear sometimes requires a bit of strength.
I've been told that using the wrong oil can cause issues like this although it's the first I've ever heard of it?
I'm using Millers CRX LS 75w90 NT oil.
Well I had a little play with the linkage just incase it didnt get my marks lined up when the box went back in.
It's made it a little bit better but it's still noticable.
I might have found the old oil can in the shed, so I might try switching the oil out and see if that makes a difference.
Well changed the oil today. Found out my IB5 has a drain plug in the bottom which was a massive result as it took about 20 minutes to drain and refill.
Used some other millers GL5 stuff I had knocking around in the shed, which is what I assume went in it when i first got the gearbox, and it's made a world of difference
TPM961
15-01-2018 10:50 AM
Adam Graham
06-09-2015 06:04 AM
