Sponsored by:
Sponsored by:
zetec turbo alternator set up in a S1
Old 16-07-2015, 05:36 PM
cossirob
cossirob's Avatar
Default zetec turbo alternator set up in a S1
Hi guys im after a little bit of advice. Im currently fitting a silvertop zetec turbo into my S1 and am slightly stuck when it comes to the alternator setup. I just tried fitting a fiesta xr2 alternator bracket and a s2 70amp alternator, iv seen it fitted to a load of s2 rst's but the alternator is hitting the anti roll bar bracket in mine
Could anyone give me a bit of advice? do i use a different bracket?
This is what iv tried fitting
Thanks rob
Old 16-07-2015, 06:59 PM
studabear
studabear's Avatar
On my mk4 I used a escort rst alternator bracket and a lowering bracket I purchased on ebay, this dropped the alternator and sorted the issue as I first tried using a frst bracket.
If you have a erst bracket bolt it to the engine with the top holes in the bracket bolted to the bottom holes on the block and see if that will be any help? (hope that made sense)
Picture may help a little.
Old 16-07-2015, 08:24 PM
cossirob
cossirob's Avatar
Makes sense and thanks for the pic but my problem is the s1 anti roll bar mount, i cant lower my alternator because itll hit the roll bar mount
Old 16-07-2015, 08:41 PM
studabear
studabear's Avatar
The escort bracket sits the alternator above it, which could solve your problem.
Old 16-07-2015, 09:54 PM
cossirob
cossirob's Avatar
Smile
Where do you get that bracket from
Old 17-07-2015, 06:33 AM
studabear
studabear's Avatar
That is a copy of a escort rs turbo bracket, so you want a bracket of a escort rs turbo or a xr3i. You might still need a bracket to make it sit lower.
Old 17-07-2015, 08:10 AM
cossirob
cossirob's Avatar
Iv brought a rst bracket from ebay so il see how i get on. Do you know where i can get a lowering bracket from?
Thanks rob
Old 17-07-2015, 08:21 AM
studabear
studabear's Avatar
I got mine on ebay not seen them for a while though
robnock
21
13-05-2019 05:29 PM
robnock
22-08-2015 10:51 AM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: zetec turbo alternator set up in a S1
