Hand brake light on
the mondeos handbrake light is flashing randomly while driving so what could this be a symptom of?
Does it do anything other than tell you the hand brakes on? On the Sierra it was a low fluid warning light and abs pressure etc so rather than just change the switch is rather have a proper fix
It comes on for a second or so, flashes a few times then out again
Or it will come of for a few seconds and then go out
All while driving on smooth roads and not after bumps or the like
If it was any other light I'd wait till I got home but obv brakes are the one thing you can't ignore
I've got some fluid and copper grease now so when the time comes I'll figure out how to get the wheels off and go from there
If I didn't need to access the bleed nipples on the other side of the caliper is so it from within the spokes and not even need a jack
Yesterday in the rain I decided to have a look
Other than the rear brakes being almost rusted solid into place the off side bleed nipple was leaking slightly
So a full rear refurb and a replacement nipple from my stack of parts and a fluid top up means it should all be sorted now
And the level is difficult to gauge as its a bit deceiving
