4x4 cossie rear discs
Hi Guys,
I need to replace my rear discs on the sapphire. I am running the 4x4 rear discs and callipers, but can only really find EBC discs or discs from Burton power branded National Sport.
ideally I would go for the 325mm conversion but funds don't allow at the moment so just need to replace the standard discs.
whats everyone using/recommend?
I would go Burtons. I have never been impressed with EBC. I would avoid all the grooved stuff as they just seem to cause noise. There is a ford specialist on here that people recommend, I will try to find the name.
the ones from burton are also a lot cheaper around £100ish instead of £160ish.
that would be helpful. I have looked at the normal places like reyland, matt lewis, R and B etc but cant see any good quality standard discs, just then upgrade kits.
I was just searching and was going to say Matt Lewis. Have you spoken to MT and MK Motorsport and see how cheap you could get the upgraded 325mm kit for as they may be cheaper than the bigger suppliers. I think I was in the £300's but the disc size is massive in comparison. I know you said that the money was a factor though. Oddly enough I have some good fronts that you could have had for nowt shame not the rears.
not sure about the MT and MK kits, but would guess them to be about the same cost, as the cost is really in the discs and bells.
yes you can get them from euros, but they are only a budget disc, and although don't want to pay for the conversion I do want a good quality disc, that will handle track use, which I doubt a cheap motor factor disc would.
due to the track use, and going for a bias pedal box i am of the opinion that the brakes can never be too good.
thanks mat, nice to hear someone using them without any problem. ill just go for them then. cant decide on ds2500 or go all out and get ds3000 or carbon Lorraine RC5+ pads
For the rear, fancy pads arent needed, the likes of DS3000 would be crap as they'd never get any heat into them.
RC5's would be better if you really had to use an uprated pad.
jason_nike
18-08-2019 10:53 AM
james kiely
28-08-2015 08:58 PM
track.focus'd
12-08-2015 05:53 PM
Graceland
31-07-2015 10:34 AM
