Think my speedo is out!
Old 12-05-2015 | 04:27 PM
RSBryden's Avatar
RSBryden
Default Think my speedo is out!
I'm 100% sure my speedometer isn't reading properly! Is there anyway to check this other than driving alongside someone telling me my speed?
Am I right in thinking there's a sensor in the box that can be changed?
Can it be repaired of better buying a replacement?
Old 12-05-2015 | 04:28 PM
RSBryden's Avatar
RSBryden
Also my rev gauge jumps sometimes and is slow to pic up revs
Old 12-05-2015 | 04:32 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
you don't have an app in your smart phone? nokia drive or nokia maps on my lumia tells me my speed.
Old 12-05-2015 | 04:34 PM
RSBryden's Avatar
RSBryden
I try not to use my phone while driving mate
Jokes! I need to get it sorted mate can't keep checking my phone I only use it for calls n texts
Old 12-05-2015 | 04:49 PM
STeve's Avatar
Moderator
use a sat nav
Old 12-05-2015 | 05:14 PM
RSBryden's Avatar
RSBryden
Would rather get the speedo fix! Instead of messing bout with a sat nav- phone every time I get in it
Old 12-05-2015 | 05:16 PM
STeve's Avatar
Moderator
if running std wheels and tyres it will just need recalibrating, but if you have changed the wheels from OE it will throw it out
Old 12-05-2015 | 06:45 PM
RSBryden's Avatar
RSBryden
Is it easy to recalibrate ?
Only had it 5 days n thinking of getting rid already ..... I must be mad,
Old 12-05-2015 | 06:49 PM
Caddyshack's Avatar
Caddyshack
You asked if there is a way to check it, phone app or Tom tom type sat nav is way to check it. If it is then found to be out due to different wheels then recalibrate.
My 205 pug was out but it was out all the way around the speed range so I just popped the pointer off with two spoons and put it back on in correct place.
Old 12-05-2015 | 06:50 PM
RSBryden's Avatar
RSBryden
Maybe that is to harsh I don't wan sell just got annoyed the mounts are gone on the box and the interior is stripped out and I have no idea were to start to refit all the sound stuff and carpet etc....
Old 12-05-2015 | 07:02 PM
STeve's Avatar
Moderator
mate the gearbox mounts are dead easy as for the rest its all very easy too even for a novice as the frst is one of the easiest cars to strip and rebuild, you need to seek a specialist over speedo recalibration though
Old 12-05-2015 | 07:37 PM
RSBryden's Avatar
RSBryden
Ok I think I'll do the mounts this week n do the interior wen I'm back of holiday! I'll keep u updated! Thanks for the support buddy
Old 14-05-2015 | 10:33 AM
cossynut2's Avatar
cossynut2
Originally Posted by 1-PD
use a sat nav
Sat Nav will always show very accurate speeds and is a good way to check how well your speedo is reading. I was suprised that my speedo reading in my 2wd with 17inch wheels and 205/40/17 track day tyres was spot on at all speeds.
Old 14-05-2015 | 10:34 AM
STeve's Avatar
Moderator
exactly as its a way of testing or if you have to use as a back up
Old 14-05-2015 | 07:25 PM
St3V3_C's Avatar
St3V3_C
Just be careful with GPS speed. It's slow to update, and depending on the system, may be affected by changes in altitude.
Old 15-05-2015 | 06:06 AM
STeve's Avatar
Moderator
I dont think altitude will be a issue in essex lol unless the QE2 bridge qualifys
Old 15-05-2015 | 07:03 AM
RSBryden's Avatar
RSBryden
Lol yeah you right , no hills here mate, just multi-storey car parks , anyways replaced the mounts, quite easy! Pulling in a straight line and runs like a dream!
cossie brad
29-09-2015 02:38 PM
IainRS1700T
25-09-2015 06:44 AM
sto6enc
Ford Mondeo Including ST
21-09-2015 11:31 AM
Bransby
14-09-2015 08:54 PM
Escortdriver1
31-07-2015 02:36 PM
Quick Reply: Think my speedo is out!
