MSD Solid Beam Mounts
Old Apr 9, 2018 | 02:54 PM
  #81
fuzzy's Avatar
fuzzy
14000+ post superhero
I've no idea what's happening here really but won't the bigger standard rubber mount be compressed under load so ends up the same size as the solid mount once fitted ?
Old Apr 9, 2018 | 09:09 PM
  #82
PAUL S's Avatar
PAUL S
No, as the torqued up depth is dictated by the central pin also shown in the side by side pics.
Old Apr 10, 2018 | 03:13 PM
  #83
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Lol I’ll live with it as is as dose all the others who have fitted them
Old Apr 10, 2018 | 04:04 PM
  #84
The Youth.'s Avatar
The Youth.
Originally Posted by PAUL S
Further info:-
They are simply an aftermarket clubman cheap fix, and without a properly modified beam plate they do not hold the beam in place correctly.
Dissagree to a point, the alloy or TAS (trans auto sport anyone remember them?) composite ones that I use do hold the beam fine,the bolts line up correctly and the cars I've prepped or seen prepped have been straight when checked.
Granted the OP pic doesn't look right with the plate on an angle where as the pics paul posted do fit exactly as expected.
Steve
Old Apr 13, 2018 | 10:12 PM
  #85
markk's Avatar
markk
Originally Posted by Mr RS500
Paul
Im shocked at your comments based on shit you seem to find on the net
I gave you a lot more credit than this
Im not going to comment anymore as this is the usuall PF posts from people who dont know as much as they think , and the main reason i dont use this site anymore
Thats why I stopped commenting.😒
Old Apr 15, 2018 | 03:22 PM
  #86
timsrs's Avatar
timsrs
Just out of interest
What’s the torque setting for the bolt that fixed the mounts
Old Apr 15, 2018 | 03:30 PM
  #87
Caddyshack's Avatar
Caddyshack
Depends if it is bent, or not?>..........I’ll get my coat, shall I?
Old Apr 15, 2018 | 03:58 PM
  #88
timsrs's Avatar
timsrs
Originally Posted by caddyshack
depends if it is bent, or not?>..........i’ll get my coat, shall i?
Old Apr 15, 2018 | 04:53 PM
  #89
ajamesc's Avatar
ajamesc
Do them up with a 3/4 inch air gun as you have to bend the bolt and plate if you have solid mounts lol (mine did up easily though odd that and neither is bent)
Old Apr 15, 2018 | 04:56 PM
  #90
Adam-M's Avatar
Adam-M
Has anyone measured to see if the both halves going together into the beam leaves a gap in between them to make up for the height difference?
Old Apr 15, 2018 | 05:07 PM
  #91
ajamesc's Avatar
ajamesc
No need there’s a picture of them side by side on a table and some very intelligent people have told us there wrong.
When I put the engine back in mine I’ll take mine to work remove the bolt and plate take that measurement and get more detailed pictures
Old Apr 15, 2018 | 05:19 PM
  #92
timsrs's Avatar
timsrs
Yeah got to admit bolted mine up tight and it’s not bent owt
Old Apr 15, 2018 | 05:30 PM
  #93
Caddyshack's Avatar
Caddyshack
I just did mine as tight as I could with a long spanner and no, it wasn’t bent.
Old Apr 15, 2018 | 05:41 PM
  #94
timsrs's Avatar
timsrs
Thanks
Old Apr 15, 2018 | 06:40 PM
  #95
Caddyshack's Avatar
Caddyshack
Keep calm guys, this is an interesting debate with lots of great info. We can have differing opinions but it helps everyone.
Old Apr 15, 2018 | 06:46 PM
  #96
Adam-M's Avatar
Adam-M
I agree Toby no point slagging each other or trying to make someone look stupid, quite simple, insert an alloy bush into the rear beam and measure the overall height and compare to the height of a poly bush/standard bush then case closed. No need for 3 pages of nonsense.
Old Apr 16, 2018 | 02:02 PM
  #97
Jay,'s Avatar
Jay,
Sponsor
With homologation it will stipulate where mounting has to be I.E turrets axle wheelbase and track ect but there wont be things like fixing plates listed and seeing as there were several teams building cars they would differ from others and its still the same today . And Paul s by the looks of your pics thats a group a rally beam not a circuit car beam
Old Apr 16, 2018 | 02:46 PM
  #98
fuzzy's Avatar
fuzzy
out of interest whats a djr1 and djr2?
Old Apr 16, 2018 | 02:54 PM
  #99
Adam-M's Avatar
Adam-M
Dick johnson
Old Apr 18, 2018 | 11:46 AM
  #100
PAUL S's Avatar
PAUL S
As I stated all along, its not about the current owners, its about the cars with me.
Having done some more research and also now had it confirmed by an independent RS500 expert, I wanted to rectify a statement I made on this thread about Pauls Ringhausen LUI RS500 but unfortunately someone on passionford has decided to censor the debate and removed all my associated posts!
Rather than bring it up again, to the very few people what would have read my statement at the time, I seek to now confirm that I had in fact mixed Pauls car up with its identical sister Ringhausen RS500.
For that I apologise, it was a genuine error based on what happened to the sister car at the time and its subsequent replacement.
All the other information I provided about the spec of Group A RS500s in general and their components I still stand by, however if I later find I have been incorrect on any of that I will also rectify such information.
I am a neutral party in relation to these cars, have no axe to grind with anyone, I just like facts and not conjecture, and if proved wrong will happily acknowledge such.
I do not agree with one sided censorship in a debate, so have no plans to keep posting anymore on this matter on passionford so I suggest interested parties also do their own independent research.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
