FAO DINGY
Old 03-04-2005 | 01:43 PM
Zetec Andy's Avatar
Zetec Andy
My brothers CRX used to do the same thing rudey, after doing a search and asking on CRX forums it turned out the be a break in the soldering on a circuit board down near the drivers side footwell, quite common apparently, re soldered it and all was fine
Old 03-04-2005 | 02:10 PM
Zetec Andy's Avatar
Zetec Andy
Just done a search on the CRX forums and found all the info!
There are solder joints in the Main (fuel) Relay that crack and cause problems starting. At first, it seems to fail after running a short time (usually when re-fueling, making a quick stop etc.), or after it has warmed up. This will continue sporadically until later on, then it will fail completely
1)Take the main Relay out from under the dash (usually near the fuse box), and pry the black plastic cap away from the under-side (plug) of the relay.
2)Look at the solder joints carefully with a magnifying glass and you will probably see a tiny circular crack around one of the joints.
3)Re-solder that joint (and any other joints that you suspect).
This should stop all your problems.
More info including diagrams and pictures here...
http://www.marklamond.co.uk/howto/el...main-relay.htm
Old 03-04-2005 | 04:12 PM
Zetec Andy's Avatar
Zetec Andy
no worries pal
ImaRacing 700
27-07-2005 08:24 PM
BillyCabrio
32
25-06-2005 02:23 PM
Disabled Account
14-06-2005 06:17 PM
61
24-03-2005 09:11 AM
Azrael
17-02-2005 09:26 AM
Quick Reply: FAO DINGY
