Anyone know anything about tuning an st170 motor??
Kapow!!
I have a mk3 fiesta track car, currently a 1.8 silvertop zetec.
What the best way to get 250bhp without forced induction?
Obviously il have to spend a few quid, but what options do i have if i go down the st170 route?
Will the lump bolt straight in the same as the silvertop?
You're either dreaming or will need very deep pockets.
ST170 isn't a straight bolt in affair as we found out doing the conversion on my brothers mrs Escort GTi. I would suggest a better option would be the 2 litre silvertop on throttle bodies but you'll be a wedge short of the 250 mark
Why start with an expensive st170 engine when you're foing to have to get loads of headwork done, new pistons/rods etc, you may as well just start with a boggo silvertop
by the time youve got a peaky nasty to drive 250bhp out of one of those you may as well have bought a duratec and got the same power cheaper, because the zetec will bankrupt you for that power, and you wont get it right with the first attempt anyway in my experience
If you insist on the zetec, or the duratec for that matter then have a trawl of the kit car/caterham/westy forums as they all have better info than on here
I'm not sure you realise the cost of that power target?
If you are worried about turbo lag or reliability issues with forced induction I don't think you need to worry really, a well mapped 250bhp zetec turbo will be very punchy will very little lag and can be very reliable too.
I was offered a silver top for cheaper lol. You're missing the point, if you are gonna have to change the rods, pistons and do valve train mods as well as Port the shit out of the head then you might as well start with the cheaper engine. If you can get an st170 for peanuts then great.
Problem with the silver top is cam choice, running wild cams will need oversize bucket bores and just the machine work is Ł350+
ST170 wild cams don't need that machine work as cam have been developed well over the years and don't need bucket machine work. And the there are so many cams on the market for these engines.
I've discussed all this with Andrew@ALD as he will be building me my engine for my Fiesta.
If I was the OP I would deffo not look to tune the zetec to 250 n\a unless its required in the regs for a race series......Duratec would be far easier
![](https://passionford.com/forum/images/smilies/roi.gif)
Surprised nobody has mention the 2.3 lump out of galaxy's solid engines and still very tuneable with extra torque from larger capacity just will weigh a bit more.. None of these engines will go Into a mk3 fiesta without modifications, the Silvertop zetec is the only.engine mentioned so far that'd be an easy fit
Kapow!!
The car had a 1.8 silvertop as standard when i bought it.
To use it as a cheap track car this year, il just chuck a silvertop back in there.
I have an HO inlet, and will need another 4-2-1 exhaust manifold and induction kit ect. I have 130 bho 2.0 cams and ecu. With all this fitted, would there be much of a difference if i went for a 1.8 or 2.0???
While this is in the car, il build a fresh 2.0 in the garage, and how about a port / polish, bike carb kit with ignition ecu and biggest cams that will go without modifying the head?
Should that see around the 200bhp mark?
From what iv been told by people.owning both the 1.8 and 2l
The 1.8 is a more rev happy engine but the 2l has more low down grunt n torque to it..
Zetec of carbs should see around 150-160 bhp, altho it's a step backwards to go from EFI back to carb imo look about for motor bike throttle bodies still cheap set up but will save alot of hassle rather than changeing fuel tank lines etc
Problem is the 130PS engines never actually make the claimed figure. You can put money on the fact you're probably 10bhp down on the claimed stock power. The 2 litre actually gives 130bhp and has more torque. Friend did a 2 litre silver top on bike carbs and it went very well for the 160bhp it delivered.
Kapow!!
Right, ive got a 1.8 silvertop on the way, il get that in there with a series 2 box and lsd just so i can use the thing.
To go with it i have an rs1800 inlet manifold and 2.0 130ps ecu and cams.
While thats in there, i have a 2.0 head i can port, il rebuild a 2.0 engine ready to go in, get myself a bike carb kit with ecu- but whats the biggest / most power gaining cams i can get without getting machine work done to the head?
I had basicly this setup in a mk2 fiesta last year and that made 186bhp. That'll do in the shed im using for now.
SMILER258
28-09-2015 09:04 AM
