General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Fitted black poly bush to me beam do I just bolt it up with plates or do the spacers go back in as the poly bush looks twice the size
Plastic spacers between plate that bolt to body I mean
Someone on the RSOC had problems fitting these
He asked the same question, could not bolt it up the body as the bush was so hard it would not compress. He rang Powerflex and they said "Yeah they're pretty stiff aren't they, you'll have to cut them down"
I'm sure you can do it, if you jig it around enough, but yes you should only have 1 bush and 1 steel tube (and a small packet of copper grease)
