ST170 engine management?
Old Feb 20, 2015 | 06:08 PM
d5_fez's Avatar
d5_fez
Default ST170 engine management?
eml came on, had a read and got these:
believe the imrc is a common fault! can it be fixed or is a new unit needed ?
had a quick goggle of the others seems to all be intake related! hate it when the cars not running just right! 👎 anyone experienced similar faults/codes?
P0181 - fuel temp sensor circuit a range performance
P0761 shift solenoid c performance or stuck off
P1518 - intake manifold runner control stick open (bank 1) (see p2004)
Old Feb 20, 2015 | 06:13 PM
RichieST's Avatar
RichieST
If you reset the codes do they come back?
Old Feb 20, 2015 | 06:25 PM
d5_fez's Avatar
d5_fez
yeah mate! clear them and then there back again!
Old Feb 20, 2015 | 11:25 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Have a looksie here vid explaining what to do.
Old Feb 21, 2015 | 04:19 AM
When you turn the ignition on the imrc will pull on the cable and open/close the flap. Get someone to switch the ignition on and see if you can see this happening.
You can take the imrc box apart and clean the electrical connections with some sand paper. A finger nail file is ideal.
Old Mar 11, 2015 | 08:20 PM
d5_fez's Avatar
d5_fez
had it in at my local garage getting a second look, they say a new imrc/second hand one. but looking at the price of a new one, think i'll give this go - hopefully this weekend.
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
