indicators etc are playing up.*problem solved*
Old Apr 1, 2005 | 02:13 PM
tonyturbo's Avatar
tonyturbo
Default indicators etc are playing up.*problem solved*
rite. on a 90 spec xr3i the indicators have stopped working. hazard lights still work tho. do they have seperate relays? i have changed the indicator stalk and its just the same. what else do you reccommend looking at??????
*update*update*update*update*
when you start the car and you go to turn it off again the engine turns off but dash lights etc stay on.
when you flash main beam it blows no 16 fuse and the drivers side headlight stays on permanently whether ignition on or off......
indicators still dont work
fuse 13 is for indicators and reversing lights. the fuse has been removed and the reverse lights still work.
help me please.....................
Old Apr 1, 2005 | 02:23 PM
pugo's Avatar
pugo
fuse??????? or relay(yes its seperate)
pugo
Old Apr 1, 2005 | 02:24 PM
Zetec Andy's Avatar
Zetec Andy
it could also be the indicator stalk, i had lots of trouble with my old orion.
Old Apr 1, 2005 | 02:25 PM
Westy's Avatar
Westy
Old Apr 1, 2005 | 02:29 PM
Zetec Andy's Avatar
Zetec Andy
Note to self: must read posts properly
tonyturbo's Avatar
tonyturbo
pugo
any idea which is the indicator relay?
Old Apr 1, 2005 | 02:35 PM
Cola's Avatar
Cola
Has someone chucked paint at your car or am I colour blind?!
Cola - who has been away and didn't have a high concentration span anyway
Cola's Avatar
Cola
PS: This happened to my M4 and it was the relay.
Old Apr 1, 2005 | 02:36 PM
Zetec Andy's Avatar
Zetec Andy
There are 2x TonyTurbos on here cola
Old Apr 1, 2005 | 02:37 PM
Cola's Avatar
Cola
nooooooooooo - one is enough lol
TT(2) please ignore my ramblings
TT(1) is your car still white lol
Old Apr 1, 2005 | 02:38 PM
tonyturbo's Avatar
tonyturbo
is the relay under the dash or in the fusebox?
Old Apr 1, 2005 | 03:12 PM
tonyturbo's Avatar
tonyturbo
Old Apr 1, 2005 | 04:32 PM
NUTS RuS's Avatar
NUTS RuS
has it got electric windows ?
Old Apr 2, 2005 | 11:21 AM
tonyturbo's Avatar
tonyturbo
yes it has electric windows!!!!!! why you ask that?????????
Old Apr 2, 2005 | 12:00 PM
Oranoco's Avatar
Oranoco
Do your blowers still work?
Had this on mine and it was a problem on the fuesboard as the 2 are on the same circuit. Cost next to bugger all to sort out though
Old Apr 2, 2005 | 12:05 PM
tonyturbo's Avatar
tonyturbo
not sure. i'l go and check.
Old Apr 2, 2005 | 12:09 PM
tonyturbo's Avatar
tonyturbo
no the blower not working either!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 2, 2005 | 12:16 PM
Oranoco's Avatar
Oranoco
Check the fuseboard where the relay for the circuit fixes and clean the terminals up. May be worth using a small screwdriver to bend the contacts slightly to improve the connection. You may well find this cures the problem
Old Apr 2, 2005 | 12:21 PM
tonyturbo's Avatar
tonyturbo
you any idea which relay it is??????
Old Apr 2, 2005 | 12:31 PM
Oranoco's Avatar
Oranoco
Not off the top of my head mate sorry. Was ages ago mine did it.
Will have a butchers in my Haynes manual if I can find the bugger
Old Apr 2, 2005 | 01:38 PM
tonyturbo's Avatar
tonyturbo
Old Apr 2, 2005 | 03:44 PM
Adrian's Avatar
Adrian
Car could just be having an identity crisis... Thinks its a BMW.
On my old MK4 XR3i this happened. Replaced the whole fuse board in the end.
Old Apr 2, 2005 | 04:07 PM
NUTS RuS's Avatar
NUTS RuS
it makes it easier to stick your arm out when turning right
As far as I remember the relay you need to check is next to the power window one in the fuse box. If there was a problem with the fuse box or feed then they would have stopped too Sounds easy enough to trace once you know which relay it is.... pity I cant remember either. Just clean them all up and see how it goes
Old Apr 2, 2005 | 04:50 PM
RS DJ's Avatar
RS DJ
Why don't you move to Wiltshire, no problem if they don't work no fooker use's em anyway
Old Apr 2, 2005 | 04:56 PM
essexrsturbo's Avatar
essexrsturbo
tonyturbo, im 100% sure its the yellow relay in the fuse board(the taller one) burnt out, change it then come back on hear fanking me
Old Apr 3, 2005 | 08:10 AM
tonyturbo's Avatar
tonyturbo
there is 2 yellow relays in the fuse box and guess what!! there both the same fookin size
Old Apr 3, 2005 | 08:25 AM
tonyturbo's Avatar
tonyturbo
it is 1 of the small yellow relays. the 1 nearest the right. as it clicks as normal when you run a live wire into the left side of indicator fuse holder.
any more ideas guy's??????
Old Apr 3, 2005 | 10:40 AM
NUTS RuS's Avatar
NUTS RuS
Are you saying its dead before the fuse too ???
Old Apr 3, 2005 | 02:21 PM
tonyturbo's Avatar
tonyturbo
yes. no power to the fuse.
Old Apr 3, 2005 | 05:47 PM
tonyturbo's Avatar
tonyturbo
right this will take some explaining!!!!!!!!!!!!!!
if i run a wire from the battery to the fuse holder in the fusebox for the indicators they work no probs,
but if you put the lights onto mainbeam the wires try to melt!
also with this wire connected i have power at the blower but it still doesnt work!!!!
i have the clocks etc removed an unplugged from the instrument cluster and the drivers side mainbeam stays on until you connect the instrument cluster back up doesnt go off with ignition either. also found the remains of an old immobiliser loom under dash so removed it just incase. still the same tho.
wired to the fuckin moon it is.
Old Apr 3, 2005 | 07:13 PM
tonyturbo's Avatar
tonyturbo
Old Apr 3, 2005 | 07:19 PM
essexrsturbo
hmmm.... well mine wen suddenly and it woz one of them yellow relays that had burnt out in the fuseboard, try it
Old Apr 3, 2005 | 07:23 PM
NUTS RuS's Avatar
NUTS RuS
Yep, the relay could be causing the short circuit. But you say it works ok if you power up the fuse .... so ......
Got to check back in the loom from before the fusebox to look for a short somewhere. Has it blown the fuse your powering up manually ?
Old Apr 3, 2005 | 07:25 PM
Moonie's Avatar
Moonie
Sounds to me like you need to start from scratch...
Look at which circuits are not working/faulty, then look at these circuits on a wiring diagram and see if they have anything in common (feeds, earths, fuses, splices in the loom etc etc).
Make sure all fuses are ok and all wires are connected to the battery (the small ones as well).
With the help of the wiring diagram and a testlight go through the circuits starting from the battery, the fuse, the component, the earth and all the wiring in between.
If you just start swaping relays about etc you may cause more harm.
Old Apr 3, 2005 | 07:36 PM
TrickyDicky's Avatar
TrickyDicky
the indicator relay is black and its plugged into the indicator stalk/switch assembly.
hth
Old Apr 3, 2005 | 07:39 PM
tonyturbo's Avatar
tonyturbo
hth
yes. there is also a yellow one in the fusebox!!
Old Apr 3, 2005 | 07:45 PM
tonyturbo's Avatar
tonyturbo
changed the relay and it made no difference..
the fuse i am powering manually is fine...
have started stripping the black tape off of the loom at the indicator stalk and following it back to the fusebox. lost a bit of time today as spent most of the afternoon at casualty as the girlfriend came off her horse and wrecked her back and neck muscles. never mind. the car was goin for an mot at half 10 tomorrow so looks like itl be getting cancelled!!!!!
Old Apr 3, 2005 | 07:48 PM
tonyturbo's Avatar
tonyturbo
i havent really got a diagram for the 90 spec escort as the mk4 escort haynes manual doesnt include it. will it be same as normal early spec escort???????
NUTS RuS's Avatar
NUTS RuS
Which side of the fuse is dead ??
Old Apr 3, 2005 | 07:52 PM
tonyturbo's Avatar
tonyturbo
both sides of the fuse is dead. if i power up the right hand side it does nothing and if you power up the left hand side it works the indicators etc.
