Help needed please
Old Dec 27, 2014 | 10:55 PM
bannedalot's Avatar
bannedalot
Default Help needed please
Hi guys I have a 4x4 saph Cosworth and it's been acting funny like going on 3 cylinders and clearing and wount start now I am getting spark (running wasted spark) it's like it goes to start but wount keep running... I think it might be a map sensor it blew the vacuum hoses off but there all back on I also had similar problem with my Escort Cosworth a couple years ago where's the best place to get a map sensor? Has anyone else had this problem?
Also I be done a compression test and all pressures are good and changed the plugs.
Ohh while I am here what do I need to do to get my rev counter working as it's not working since fitted wasted spark?
Thanks in advance
Scott.
Old Dec 29, 2014 | 09:33 PM
martysmartie's Avatar
martysmartie
I think MSD supply instructions, but you need to do a mod to it.
A bad MAP can cause that problem, as it will run rich, you can do a diagnostics on the ECU with an LED (or just use a multimeter, as I believe the diagnostics only shows an open circuit.) I think MSD supply them.
It's a good idea to cable tie the pipes, especially the FP one, as if this comes of it can end up in a catastrophe.
Martin
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
