race technology dash 2 programing
Old Dec 2, 2014 | 12:21 PM
RIB1122's Avatar
RIB1122
Default race technology dash 2 programing
anyone got one or wants to do mine if i send the file across for a drink?
Old Dec 3, 2014 | 06:10 AM
M K's Avatar
M K
I need to sort mine as well,
Got a few things working but need to set up the rest
Old Jan 26, 2015 | 10:58 PM
M K's Avatar
M K
Just been setting mine up with the ecu interface I bought with it for my life racing ecu,
got most things sorted other than the oil pressure and the battery voltage! this seems to be an equation issue in the dash2 config files
Old Jan 26, 2015 | 11:15 PM
M K's Avatar
M K
Anyone clued up as to what equation I would need to enter into the dash2 config software to enable to oil pressure and battery voltage to display properly
I cant seem to enter what it says to convert with in the LifeCal software
Old Jan 27, 2015 | 10:27 AM
stevieturbo's Avatar
stevieturbo
C**t
Can they not supply a CAN config for it ?
I know a few Syvecs guys recently posted about them having trouble getting the Dash2 working with theirs.
I think they got there in the end though, but RT werent overly helpful.
Old Jan 27, 2015 | 10:42 AM
M K's Avatar
M K
Im emailing back and forth with a fella from RT now and he is helping with the solution, just seems the info for bat and oil pressure is not coming through the can, i sent him the config file for the can today, may need an update and reflash so waiting for him to get back to me, he has been very helpful though so far
Thought maybe it was a sensor fault for the oil pressure but i am using the same zhyq pressure sensors for both fuel pressure and oil pressure and even swapping them round the oil pressure readout is scaled to max? no idea on the battery voltage either as yet
Old Jan 27, 2015 | 12:38 PM
JonnyBravo's Avatar
JonnyBravo
Best to ask a doctor
Old Jan 27, 2015 | 12:45 PM
stevieturbo
C**t
Seems they are all Doctors at RT though !!
I tried to get the Dash2 running via CAN with my DTA ecu a few years ago. I gave up in the end and sold it. Nobody was offering any help for me.
Old Jan 27, 2015 | 04:50 PM
M K's Avatar
M K
All sorted now, got everything showing on racetech dash2 with ecu can interface
Rpm
Oil temp
Water temp
Air charge temp
Oil pressure
Fuel pressure
Boost
Battery voltage
Throttle position
Everything checked against live data stream from LifeRacing monitor
I have been dealing with a bloke called Sam Knight, couldn't be more helpful
Old Jan 27, 2015 | 06:31 PM
gus's Avatar
gus
Cool beans
Hope for mine yet lol
Old Jan 28, 2015 | 08:58 AM
smiley's Avatar
smiley
Rpm
Oil temp
Water temp
Air charge temp
Oil pressure
Fuel pressure
Boost
Battery voltage
Throttle position
What was the problem mate?
Old Jan 28, 2015 | 10:39 AM
M K's Avatar
M K
The interface configuration was wrong
But to be fair I did buy it 3 years ago so no wonder things have changed a bit with the Ecu readings
Old Jan 29, 2015 | 02:19 PM
smiley's Avatar
smiley
ah thanks mate may encounter this soon
Old Jan 29, 2015 | 02:22 PM
M K's Avatar
M K
Just realised we are not getting anything on throttle position so working on that now
Old Jan 30, 2015 | 10:33 AM
M K's Avatar
M K
Was another issue with can interface config, had that changed and now showing throttle position on dash2
A ball ache sorting this all out and has taken me a week of messing around with it and emailing back and forth but worth it i think to get all the ecu info straight to dash,
I was doubtful as almost every car i have previously seen with the race tech dash2 display had not had it set up as owners mentioned it being difficult etc, they normally just do speed, water temp maybe and thats it
Not as easy as some but good once working
Old Jan 30, 2015 | 03:48 PM
gus's Avatar
gus
Well look on the bright side
More you play with and learn
Easier mine will be to do
Old Aug 27, 2021 | 11:45 AM
Shaldon Pienaar's Avatar
Shaldon Pienaar
Default RS2000 MK6 Ford escort.
Hi guys is there anybody that can maybe assist me with the wirring diagram of the MK6 RS2000 or maybe just a pinout from the fuse box iam struggling to find it online please if anybody can assist.
Tnx in advance
Old Sep 7, 2021 | 03:38 PM
anilkayn's Avatar
anilkayn
Speed Test
berkut
17
Oct 31, 2018 09:58 AM
NEIL A
286
Dec 23, 2015 10:42 PM
turboroots
83
Dec 21, 2014 05:48 PM
andrewg
220
Nov 22, 2010 06:44 PM
petermintrst
Jul 29, 2007 12:55 AM
