help please..
Old Sep 21, 2014 | 12:35 PM
DirtyB's Avatar
DirtyB
Default help please..
Ok so i bought my first zs yesterday.. really happy with it!
I have a halfords special air filter lol.. had it laying around in the garage..
Stupid question maby but can this go onto my new car? Mk5 zs.. and where should i join it? Do i take the block with plugs on it off? Or attach to that section? Thanks
Old Sep 21, 2014 | 12:48 PM
RichieST's Avatar
RichieST
What do you want it on for? Performance increase or just a bit of noise?
Old Sep 21, 2014 | 12:51 PM
DirtyB's Avatar
DirtyB
Well i know performance is minimal but slightlt more responsive and the noise really..
Old Sep 21, 2014 | 01:01 PM
RichieST's Avatar
RichieST
An aftermarket air filter will probably loose you power as it will just suck in hot air from the engine bay. The standard set up is good enough, if you want the best performance then put in a performance panel filter into the original air box. If you want noise then remove the air filter box and mount your new filter on to the end of the air flow meter, but be prepared for it to use more fuel and probably not perform quite as well.
Old Sep 21, 2014 | 01:02 PM
This is how I joined my filter on my Poooma.
Old Sep 21, 2014 | 01:04 PM
I took the air box right out and fitted a plastic panel and used the original induction hose for a good cold air feed to the filter.
Old Sep 21, 2014 | 01:25 PM
DirtyB's Avatar
DirtyB
Glen is that cold air feed just the bottom section of the original air box? Or is that a feed youve run from a front foglight hole?
Old Sep 21, 2014 | 01:27 PM
DirtyB's Avatar
DirtyB
Also.. there is a plug that goes into the top of the air box.. what dobindonwith that plug? Just leave it out?
Old Sep 21, 2014 | 01:28 PM
DirtyB's Avatar
DirtyB
What do i do*
bonus_boy
20
Apr 5, 2009 07:28 PM
Mjcool300
Jan 30, 2009 10:59 PM
SS1
37
Dec 26, 2008 09:25 PM
GiRO
Apr 22, 2007 08:13 PM
