NEED TO TEST A COILPACK!!!!! HOW????
as above need to test a coilpack and need to know how to do it!!! Obviously want to know how to trigger it, i.e. earth the trigger earth wires to each side, but where????
I presume the ecu trigger wires into the ign amps????
Any help greatly appreciated!!!
2 greens on the plug are earth mate...the middle wire is a live, on the bench with a lead and plug attached one on each side switch 12v onto the pack, earth one side you should see a spark at the corresponding side, same again with the other side earth out, spark.
Hope that what your after.
Regards
Regards
Going to say, if it is individual all they do is split the live feed to the 4 packs....same principle applies, one wire can't remember the colour is live the other is earth but don't just wire to earth for the purposes of the test put a live feed to the pack then switch the earth to see the discharge at the plug !!
TPM961
15-01-2018 10:50 AM
