differences between 3dr to saff
Old Mar 29, 2005 | 06:57 PM
pugo's Avatar
pugo
Default differences between 3dr to saff
does anybody on here know what the differences are between 3dr runnig gear and 2wd saff running gear or is it a straight swap over
i am going to start a 3dr build and am wondering whether to just buy 2wd saff running gear or original 3dr running gear
i am talking about front xmembers aswell as rear end
also does the 3dr have power strg??or just rack and pinion and is the abs system the same on both cars
sorry for all the questions but i guessed you lot would be the best to ask
pugo
Old Mar 29, 2005 | 06:59 PM
RichardPON's Avatar
RichardPON
As far as I remember, the 3dr hubs are slightly different, and the rear ARB mounts differently on the beam.
Old Mar 29, 2005 | 07:00 PM
Rene's Avatar
Rene
3dr has power steering
Old Mar 29, 2005 | 07:02 PM
pugo's Avatar
pugo
Pon are we talking front hubs here or rear or all???????
cheers rene, that is what i thought but i just went on a cosworth spec site and it said 3drs had non powered strg just rack and pinion
Old Mar 29, 2005 | 07:04 PM
S2martin's Avatar
S2martin
Ex Full Price gold member
Funnily enough i was chatting to Brom about this the other day and he mentioned some difference between the bulkhead too as i wanted to swap all my saff running gear onto my 3dr
Martin
Old Mar 29, 2005 | 07:08 PM
pugo's Avatar
pugo
cheers martin, but what needs changing on the bulkhead, the abs mntg position???? is it because its different or is it because of something else
Old Mar 29, 2005 | 07:09 PM
S2martin's Avatar
S2martin
Ask Brom as it went flying right over my fookin head
Martin
Old Mar 29, 2005 | 07:10 PM
SPADGE's Avatar
SPADGE
Nearly everything from a saff will fit onto a 3 door!
The main differences are the front hubs + arb, the rear arb and arms and the gearbox crossmember! Pretty much everything else will fit.
Old Mar 29, 2005 | 07:14 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
here you go
all cossie are fitted with ABS
the bulkheads are the same
3 doors use different hubs and botom arms to sapphire but alkl are interchangable
3Doors have a slightly diffrent front roll bar
3 Doors have a different rear anti roll bar as its mounted on the out side of the rear arms plus its thinner
Iam led to belive a sapphire roll bar will not mount into a 3 door shell due to the hole mounting points
The gearbox X member is also different to a sapphire so this would also have to be changed
Old Mar 29, 2005 | 07:17 PM
S2martin's Avatar
S2martin
So does that mean the complete abs could be removed from a saff and put into the 3 door?
Martin
Old Mar 29, 2005 | 07:20 PM
SPADGE's Avatar
SPADGE
Martin
Yes!
Old Mar 29, 2005 | 07:22 PM
Dirty Harry
Super Moderator
you will need to use a 3 dooe wiring loom as the sahhire one will be a bit messy to fit I do have a proper one if needed
S2martin's Avatar
S2martin
Thanks Spadge and Pete
Martin
ps sorry pugo thread hijacking
Old Mar 29, 2005 | 07:24 PM
SPADGE's Avatar
SPADGE
So basicaly what i said then Pete
The 3 door rear arb is wider and mounts to the outside of the rear arms where as the saff one mounts to the inside of the saff rear arms! The 3 door rear arb also mounts onto the chasis in a different place which is why a saff one won't fit!
Old Mar 29, 2005 | 07:27 PM
SPADGE's Avatar
SPADGE
As Pete says above!
The reason for this is that the 3 door abs ecu is located behind the drivers footwell side panel where as on a saff it is located above the engine ecu on the passenger side of the dash. This means the loom for the 3 door will be longer but will still fit
Old Mar 29, 2005 | 07:28 PM
Dirty Harry
Super Moderator
your the man I didnt see your reply hence mine
Old Mar 29, 2005 | 07:35 PM
SPADGE's Avatar
SPADGE
I guessed that and was only teasing you Pete
Old Mar 29, 2005 | 07:38 PM
S2martin's Avatar
S2martin
Do you mean the engine loom or the actual car loom as i have a new pectel engine loom sitting here but no car loom for the 3 door?
Martin
Old Mar 29, 2005 | 07:39 PM
SPADGE's Avatar
SPADGE
Martin
Your engine loom will be fine
We are talking about the abs loom which attaches to the car loom!
Old Mar 29, 2005 | 08:12 PM
pugo's Avatar
pugo
thanks guys..........as you have probably worked out i am about to embark on building 2 3drs with s2martin........so you breakers boys better be ready for a large influx of cash coming your way
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
martynhomer01
Oct 1, 2015 12:05 AM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
