mk6 fiesta bang from rear nearside
As title, got a very loud bang from the rear suspension on passenger side of my 2005 fiesta, also the rear passenger side trys to follow bumps, any ideas as to what this is? Thanks
Shocker??Get the car jacked up and have a look.The rear beam bush might be worn.If it is when you shake the wheel side to side you should see and feel the play.
You could also get a wheel brace on the wheel nuts,go to tighten them and you should feel the play in the bush.
Check to see if the strut top/shocker top bush isn't worn either.
Yeah shocks are gone, had same problems when I bought my ZS changed the shocks now its perfect. You don't even need to get inside the car to do it.
1 bolt at the bottom take the wheel archer liner out and there's 2 bolts on the top inside the arch, easy job
vdun01
Ford Fiesta
05-10-2017 08:14 AM
155lee
14-09-2015 07:37 PM
