Could a Bump start cause a miss fire???
Went to start the cosy today and the battray was flat so rolled it out the garage down the drive and it started up and was miss fireing.took it up the road but would not clear. so i changed the plugs no 1 was coverd with fuel the rest where dry new plugs still no better
car was running perfect last time a used it
what could it be? would A Bump start break anything??
going to do a compression test and go from there
it has been known mate, we had an escort gti in, jumped it one day when battery was flat and it never run right again-we had to swap the ecu and keys in the end-that sorted it! seems strange that it only occured after the jump, an ecu specialist told us that you should only jump with a "spike/surge" protected leads.
hth
Tricky
hth
Tricky
hth
Tricky
hth
Tricky
Originally Posted by CraigN
low charge
youve got a flatt battery so spark will be weak
you need to drive it a bit or charge the battery
Sorry i did bump start the car rolling not jump start
Originally Posted by Lee Reynolds
need to check what voltage ur getting Doo...
iirc 13.4 or something needed at ECU.
On my escos, my battery was low and i was getting a misfire. Also i have heard this before. Stus ya man tho
Stu @ M Developments
41
21-08-2015 06:47 AM
ekjim
17-08-2015 08:57 PM
