Fuel Cooler
Fuel Cooler
Ive noticed when getting under half a tank in the cossie the fuel system starts to feat up and when lower the pump gets noisy and sound like its aerating the fuel !( obviously this is driving it like a complete tool for at least half an hour ) So doing some research and found most modern turbo diesels run a fuel cooler due to pressure and delivery heating the fuel up to help with density .
So although yes you could keep the car brimmed full but then no more fuel station roulette and wheres the fun in that ! And from what I understand cooler the fuel the denser it is = more power and and a better
So just wondered does any one use on or can shed a more of a technical if buts and what for ?
If you think of the winter climates the fuel must be very cold compared to summer.
Fuel can act as a coolant can it not? so the cooler the better maybe especially with big boost.
Does the pump aeriate under normal conditions under half a tank? Could be a duff pump mate i had 'new' pump that lasted no time aeriated and changed it and solved it.
Is it the original tank?
1. measure/log fuel temperature.
2. If you deem it too hot, fit a cooler.
Job done
Ive been recording mine for a few years. Rarely when moving does it exceed 40-45degC. Although I do have a badly placed cooler under the car. Typically those temps would also be on very warm days, so not unreasonable. Generally they'd be around 30degC though.
That's with a couple of pumps, fairly large tank rarely below 30 litres capacity, and a pretty hot engine bay/fuel rails. So a fair amount of heat getting transferred to the fuel from the hot engine.
There are literally hundreds of cooler options, just find one that fits, stick it on the low pressure return, and that's it sorted.
Job done
Would colder fuel help drop charge temps?
In the inlet surely spraying cold fuel into the air will help drop temps?
Maybe not enough to notice a gain tho...
