zetec turbo help
PassionBMW.com Member
Cossie can be made to work, but its an arse as it doesnt accept the 36-1 CPS signals or coilpack output as standrad.
Will work out cheaper, easier and better to go with another aftermarket ecu, Omex, SECS, Autronic, Pectel etc......depending on the size of your wallet and availibity.
If hes not too busy already riding around in LYCRA on his bike
was good to see ya on weekend! I'll be down very soon m8 for a few (bigdrink: & plenty of pizza! its about time we violated ummm's again!
new oversized fat bastard pizzas on sale!!!
uuuummmm stella!
Recon could be on for weekend after central day! as the weekdns b4 r all ready booked up!
gunna be a good ngiht out on the 9th if u up for it! all r welcome! & can crash @ mine!
uuummmm Bristol in the summer time! lovin the fact Im single!
cooooooooooooooooooonts
No lycra today, its raining!
Cheers for the ABS parts lewis
Sy, Get that stuff i asked you about today please, rob rob
Sam 400m please
Sam 400m please
Ask me a question!
Originally Posted by fqdata
im intending to run dissyless spark(coil pack)
is this possible
is this possible
Been done!
You need to have the parts ready to bolt on then its easy if you have the help from the other end.
Dont let anyone tell you otherwise!
You will need a EFI converter to be able to bolt on a CVH EFi inlet manifold with all the cosworth components + a few trick items one off stainless steel i.e TPS, ISCV, ACT, IGN AMP WATER SENSOR, MAP, ECU LOOM ETC.. THEN>
FRST COIL PACK, LEADS, BRACKETS etc.
A SUB LOOM (FOR THE EXTRA IGNITION AMP AND COIL PACK ETC)
P8 > Or MODS to a L6/L8 ecu
Crank pickup sensors and pulleys come either 36-1 or 4 pickup points.
Phase components direct fittment for 16v (NO DIZZY!)
If you have a tight fit 16v ZETEC ways of not even having a crank sensor have been made. E.g kit cars with ZT 16v, Pinto, YB COSWORTH!!!!!
No time to go in depth
Have a lookski here:-
https://passionford.com/forum/viewtopic.php?t=89978
Regards
Jano
