MoT question - Seatbelts
Are there any MoT testers on here who can answer a query for me please?
I've got a camper van that I'm converting and have fitted a rear seat frame with 2x 3 point belts - How are the belts tested, other than for their retraction? They're mounted properly to a metal frame which is bolted through the floor, and while I'm confident they're 100% safe for my kids, I've not had them safety tested in any way, and can't find any info online which tells me what they're tested for.
I'm presuming (hoping) that all they test is whether they lock and retract...
It's only a four seater Dojj - I read the MoT guidelines, but there's so much info, it's hard to know what's applicable!
Gingerturbo - So you just test the seatbelt operation, even on non-standard seats?
This is the seat -
And here's how it's bolted through the floor.
This is the seat -
The annoying ginger guy
Yeh as the same apllys to bucket seats where they have harnesses instead of a retracting single line belt, the still need to hold the occupant across the waist and over a minimum of 1 shoulder, as its a camper van the seats only need to have a secure bed(for the passenger to sit) and a minimum of 2 secure points the can be locked and released,
Is it a class 4 or 7
The V5 says it's 3500KG Gross, so does that make it Class 7? If so, what difference does that mean to the MoT? Also, it's registered as a panel van, not a campervan if that makes any odds.
And the seat folds down to make a bed.
You can tell I've never owned a van before! I have no idea what I'm doing!
If its registered as a panel van still then it'll be class 7, we can still mot 3.5ton vehicles as class 4 on certain circumstances I.e camper,carravanette, ice cream van etc
There's not a massive difference in class 4-7 other than load,weight, emissions I'm no expert as our station is only up 2 class 4
It's a LWB Renault Master. Yes, I know, not a Transit ![/QUOTE]
Hey I'm not going to judge mate , I'm in the middle of doing a Renault trafic conversion lol
Fart of the Purniture
LOL!!
On a serious note, it looks safer than most Sierra's that haven't had the 25 year old seat mounts looked at yet.
And on another note, I recently got and stripped out a base model 3 door, the holes and everything are there for seat belts, If I get some from a 5 door mk2 Sierra will they do the job? Does anyone know?
Here's the guidelines from the IVA test, which has more indepth standards than MOT;
Note 3: A suitable single bolt fixing of adequate strength would be, for example, a bolt of at least 11mm (7/16") diameter of grade 8.8 (the grade may not be shown on a bolt produced for a seat belt anchorage)
Other bolt fixings may be acceptable providing they are of equivalent strength.
Two adjacentseat belts may be secured by one bolt. In this case consideration must be given to the additional loads on the anchorage
Note 4: In order that a seat belt can be separated from the anchorage without causing damage to the anchorage, for example a mounting in the side of
a tube or box section, it is a requirement that the bolt is secured into a “fixed” threaded hole or captive nut. (The presenter may be required to
demonstrate this condition is met). The bolt may be secured into an alternative fixing, eg a lock nut of suitable strength, where access is provided to the
“rear” of the mounting to enable separation/re-attachment of the belt.
