reverse light
Old May 6, 2014 | 05:54 PM
gaz01's Avatar
gaz01
Default reverse light
noticed it was out the other day so changed the bulb checked the wiring everything looked ok so gave it a test still wasn't lighting up,so checked the fuse numb 84 in the hand book and it was alright any one know whats me next move has any one had this problem before 55 diswell focus cheers
Old May 6, 2014 | 06:04 PM
pcbp97's Avatar
pcbp97
you will have a faulty reverse switch on the gearbox fella. cheap and easy fix
Old May 6, 2014 | 06:09 PM
gaz01's Avatar
gaz01
cheers matey where abouts is it (don't say on the gearbox lol)
Old May 6, 2014 | 06:16 PM
pcbp97's Avatar
pcbp97
its at the front of the gearbox. easy enough to find, just looks like a hexagon head with a multi plug going to the centre of it with 2 wires. just unclip the plug and unscrew old one and replace .
Old May 6, 2014 | 06:22 PM
gaz01's Avatar
gaz01
cheers again mate
Old May 6, 2014 | 06:29 PM
Brendan's Avatar
Brendan
struggling with reality
is it on a fiesta? if so check your green relay..... some times they burn out and this happens!
Old May 6, 2014 | 06:39 PM
RichieST's Avatar
RichieST
Put the wipers on then select reverse. If the rear wiper does not come on then it'll be the switch. If it does then it's something else!
Old May 6, 2014 | 07:07 PM
St3V3_C's Avatar
St3V3_C
I guess you could pull the plug and short the two wires to prove the switch is faulty. Ignition on of course...
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
The Enigma
Sep 12, 2015 10:12 PM
