2.1zetec turbo cams- go full 130ps cams or mix 1 105ps cam?
could anyone here explain to me the pro's and cons of a full 130ps setup or a hybrid of 130ps exhaust and 105ps inlet cams
my aim is 275 bhp with a hybrid t34 (built to reduce the lag) 8:1 c/r standard head acralite pistons shotpeened and polished rods pro alloy intercooler omex and cosie greens
does it reduce lag when mixing cams or move the power up the rev range or give nice flat torque curve ??
any one got some roling road plots or advice to put me out of my misery?
my engine will be built in 2 weeks time and if i need to get some new cam(s) i will need to get them fairly soon before it starts geting built
Might be worth speaking to Paul Ripley too.
I would like to Know to iam also building a 2.1 Zetec turbo, same compression ratio and pistons as you, not sure which turbo to use though, think iam gonna run it in with a standard T3 and then bite the bullet and buy a GT turbo
standard 2.0 / 2.1 mondeo engine , ( lowered comp obviously ) will produce 250 hp on a t3,
Dont forget no mater what engine spec u got you still need to get fuel !! into it ,
My engine is prety much standard internals except for a 7.6:1 CR , standard cams etc, t34 turbo with a 48 housing and im producling 300hp .
However it needed 400cc injectors and a good set up from kenny @ MSD
I also used a 2.0l throttle body
I once asked Ian Howels about mixing cams and he claimed he didnt know , Maybe he does do this but doesnt want to let on .
i rember a vague conversation with someone saying tat the inlet of fuel/air needs to be a cetain ratio to what can be exhausted ,
Something about valve overlap and duration , doesnt realy mean much to me but perhaps stu could elaborate on this , and if someone can provide details of the different ford cam profiles we may be able to have a eduated guess as to what to use with our various specs .
hows the car drive with 115 cams in there mate ?
im mainly interested in how the torque curvs look with diferent cams in there rather than peak bhp
im probably wrong but a 130ps exhaust cam would let the gas out good to spin the turbo and the 105 ps cam is good at making smooth torque for town driving
so with them combined together ya probably get a nice drivable engine with flatish torque curve
but om most likly talking total crap
130ps cams come "on cam" around 4,000rpm (on an n/a at least). Ideally want to come on cam around the same time as the turbo spools up for low-down driveability. Maybe 115ps inlet and 130ps exhaust for higher power engines...?
I'll probably use 105ps inlet and 115ps exhaust eventually (aiming for around 200bhp), but planning to keep the 130ps cams at first and see how she behaves
/al
/al
Originally Posted by SimonT
I think youll find that these zetec turbos running "secret" cam's are a 105 inlet and 130 exhaust
i would pesume having a exhaust cam that lets more gas out than the inlet would aid in spinning the turbo up quicker or somthing
would love to see some rolling road graphs to compare cam combo's
Danielbetty
03-10-2015 06:01 PM
Matt Baxter
16-09-2015 08:30 PM
