Alloy Fuel Cell Outlet/Inlet Sizes
Depends on the pump, filter, how much flow needed etc.
I can see few reasons to use a fitting smaller than -10 on a tank outlet. It may be larger than many need, but it ensures there will always be enough.
If you want to use a smaller hose, you can step down. But it means the tank is fairly well future proof.
-6 fitting for any return line again would be more than adequate for even the biggest builds.
Tank breather, just let the tank fabricator sort this
Wye Valley Hardcore
As Steve said, -6 minimum for feeds and returns, that seems to be the standard. I would get a roll over valve -6 breather installed personally. Fabricator will know what to fit. Future proofing it with a -10 feed isn't a bad idea either, but apparently -6 will supply fuel upto 600bhp so depends how big you want to go.
Isnt a hope in hell I'd be forcing an efi pump to suck through a -6 fitting.
Wye Valley Hardcore
Is that still the case with a swirl pot?
I know mines a -8 feed to high pressure pump, from the swirl pot but feed to and from swirl are -6. I thought this was the norm?
And whether fuel is being pumped or sucked makes a difference.
Wye Valley Hardcore
AH Fabrications in Hereford, Brian. They've made everything on my car, swirl pot, oil breather and catch tank, radiator, intercooler etc. It's very good kit TBF. I have my old AH fuel cell for sale depending on what you need. It's in the sale section.
JK12
33
26-04-2021 12:09 PM
wheelwizardrefurbs
24-09-2015 08:35 PM
