Devasted can this be fixed?
Old Apr 2, 2014 | 05:35 PM
dampy's Avatar
dampy
Default Devasted can this be fixed?
Took my carpet out after changing seats and the bolt was just spinning and found this
Can this be fixed both sills rotted right through all the way along?
If it can be fixed how much is it likely too cost?
Old Apr 2, 2014 | 05:40 PM
dojj's Avatar
dojj
Resident Wrestling Legend
everything is fixable if you have enough money to spend on it
it took me a month to sort the floor on my sierra working a few hours every day on it
Mr S1's Avatar
Mr S1
Don't ask - I don't know
It can be fixed mate, new panels will sort it.
Cost wise I don't know, depends if you get someone to do it the 'right' way if you get my drift. A body shop would charge big.
Old Apr 2, 2014 | 05:49 PM
STeve's Avatar
Super Moderator
seen far worse fixed to almost invisible repairs, all depends on your budget
Old Apr 2, 2014 | 05:50 PM
Caddyshack's Avatar
Caddyshack
I would recommend buying the repair panels and buying a half decent gas mig welder from somewhere like machine mart, forget the hobby bottle gas and buy decent and you can learn in no time...that's what I did with no prior welding at all. I suspect you will find more if that bit is like that. Welding is very addictive...I did loads of welding on my classics
Old Apr 2, 2014 | 06:17 PM
luke19790_3's Avatar
luke19790_3
Doesn't look to bad, see if you can a get repair panel.
I'd also check at the front they like to rust there too
Old Apr 2, 2014 | 06:35 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
That's pretty small that, I'd get the repair panels and attack it yourself either that or put it into a decent body shop but expect to pay big money
Old Apr 2, 2014 | 06:43 PM
gjh's Avatar
gjh
How much does the car mean to you and how long do you intend on keeping it? If not much and not long, get it too a college and let them plate it up for next to nothing, if it means more and you intend on keeping it for some time, get a panel and get it welded in place properly, a regular garage should be able to do it for you for not too much, a bodyshop could charge a hell of a lot, but will probs do the best job of it.
Old Apr 2, 2014 | 06:47 PM
I know a lad in durham who might do it but he might have to see the car first.
Old Apr 2, 2014 | 07:35 PM
matts1's Avatar
matts1
do a bit of asking round mate and find a decent welder, I would guess that they are more likely to charge a sensible rate than a bodyshop that is going to charge you a whack per hour.
Check out some resto threads and you will see that this is small fries to what some have lurking and get sorted!
rsimark's Avatar
rsimark
you can get all the repair panels for theses, sound like you need a pair of full sills , inner sills and you can get a floor panel that goes from front to back and around half way across the floors that should sort it, dig deep if you pay some one to do it!!! all these panels are on ebay, but some motor factors are cheaper.
Old Apr 2, 2014 | 07:50 PM
matty325's Avatar
matty325
its fixable mate what car is it on excatly? check my resto ive dealt with a lot worse.just be prepared to find more as theres usually another 30% more rust not visable to the naked eye
Old Apr 2, 2014 | 07:52 PM
matty325's Avatar
matty325
get that front sound deadening off the front section as well as it looks like there may be some up there judging by the corners,hopefully not !!
Old Apr 2, 2014 | 08:29 PM
dampy's Avatar
dampy
I would be interested in a local lad doing it
dampy's Avatar
dampy
Will do bud
Old Apr 2, 2014 | 08:31 PM
dampy's Avatar
dampy
90 spec XR3i
Old Apr 2, 2014 | 08:34 PM
dampy's Avatar
dampy
Means a hell of a lot too me and I want to keep it for a good few years yet
So I want the job done properly but not too flush at the mo
An enthusiast locally would be ideal
Old Apr 2, 2014 | 08:43 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
It's metal of course it can be fixed the hardest part is finding some one who knows what there doing!
Old Apr 2, 2014 | 09:55 PM
marky_g's Avatar
marky_g
Fleet Manager
I've seen worse! New floors are about 40 quid I think look on eBay I just typed in escort floor panels
Old Apr 2, 2014 | 10:24 PM
rallycross's Avatar
rallycross
That looks quite good for a mk 4 which usually are scrap by now due to being rot boxes.
Old Apr 3, 2014 | 08:31 AM
matty325's Avatar
matty325
boy welding mines reckons he's used 8kg of welding wire so far
Russ Payne
Sep 25, 2015 08:29 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
Cos500
Sep 16, 2015 09:50 PM
landaqmabba
Sep 15, 2015 07:16 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
