Stripping bike carbs help please
Hi does anyone know what these hex's are & can I take them off
![](https://passionford.com/forum/picture.php?albumid=6577&pictureid=29340)
![](https://passionford.com/forum/picture.php?albumid=6577&pictureid=29344)
Thanks
Other thing I need to find out is where the fuel goes in
At the top are two short black vertical pipes you can see one between 1 and 2 just to the right of the first carb's top-right cover screw, the other in same place between 3 and 4, each one of which tees off to each pair of carbs 1+2, 3+4:
![](https://passionford.com/forum/picture.php?albumid=6577&pictureid=29379)
Is that the fuel inlets? Also there's this single tube in the middle underneath is that fuel return?
yea one in the middles fuel in
no return on bike carbs unless overfuelled then it pisses eveywhere lol
if space aint an issue then leave the hexs on theyre fitted for a reason and if unscrewd may cause fuel to piss everywhere
the fuel gets piped up from underneath?
am using a facet posiflow with 0-5psi regulator which i heard will be too much for them even on lowest setting
is there a way to connect them up without having to buy another regulator? thought maybe tee a return pipe off in the feed just before the carbs, run it up above float chamber height then down to the return line
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
