Twin turbo question
I'm going to be mocking up and fabricating my 2 manifolds soon for my boa conversion as was wondering what's people's views on placing the lambdas is there a specific distance away from the turbos they have to be or does it not matter due there lone perpose
And are 2 t2's sufficient for making sensible power due to the room in the engine bay and the fact I already have one
I've got a load of 10mm flat steel and some but fixings left over from a job at work unsure on the gauge but the 10mm flat should be ok for the head plate and turbo plate?
I would use 12mm - 15mm for the head plate.
pm ade500 his motor is a work of art.
Resident Wrestling Legend
t2's may run out of puff at the top end, t25's would be what i'd go for if you want power without wanting to spend months building them in the limited space
t2's on the 12v were great as they ran out of puff towards the top end due to them not being able to breathe, but with the 24v flowing much more air at 6500 you can make power all the way to the red line
oil flow is a worry though as you'll need a higher flowing pump to supply the turbos
Lambda sensors dont like excessive heat or pressure. So stick them in the downpipe at least 12" from the turbo.
I always prefer a min of 12mm for flanges. Leaves room to machine flat if they warp.
And if you can adapt cast manifolds, they can work well too and are generally fairly robust.
I was think about the oil pump as that's 2 extra high pressure runs I have to feed for the pump to handle
T2 is very vague, but then so is sensible power.
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
Ben26
27-08-2015 08:56 PM
