Audi problem
Old Mar 24, 2014 | 07:34 AM
Fordmad!'s Avatar
Fordmad!
Default Audi problem
My mate has an a4 estate which basically just died the other day.
It will start for about a second and then die.
Has anyone any suggestions he reckons its electrical but I reckon its fuel related as it starts but then dies.
Going to plug it in tomorrow but would be good to have some clue where yo look first
Old Mar 24, 2014 | 07:44 AM
RichieST's Avatar
RichieST
Could be many things. What a4 is it? Petrol or diesel? Get it on a scanner and go from there.
Old Mar 24, 2014 | 07:49 AM
Fordmad!'s Avatar
Fordmad!
1.9 diesel mate
Old Mar 24, 2014 | 07:53 AM
B19 JUB's Avatar
B19 JUB
is the immobiliser light flashing with ignition on?if the car doesn't recognise the key it wont unlock ecu so will start and die instantly
Old Mar 24, 2014 | 08:11 AM
Maxwell's Avatar
Maxwell
Irregular Poster
First problem, its an Audi
Second problem, it definately sounds like fuelling issues. Maybe a fuel rail sensor? Fuel filter blockage? Or more than likely a fuel pump.
Similar problem with my e46 330d, and turned out to be all 3 problems. Hasnt missed a beat since
Old Mar 24, 2014 | 09:19 AM
No Audi/VW dont got wrong. German reliability lol.
Old Mar 24, 2014 | 03:12 PM
Oranoco's Avatar
Oranoco
Mine's been great, 100k of almost trouble free motoring and still more squeak and rattle free than my Mrs 18 month old 207.
I would hazard a guess the immobiliser ring on the steering column is causing the problem. Which platform is it.
Old Mar 24, 2014 | 03:26 PM
Steve.L's Avatar
Steve.L
Go on audisport.net plenty lads on there have vag com
That will check it for free.
Old Mar 25, 2014 | 07:29 AM
Fordmad!'s Avatar
Fordmad!
Been talking to a few people and they say its the key at fault.
Audis are usually bulletproof!
It has done 180k
Old Mar 25, 2014 | 09:31 AM
Most cars are bullet proof if they have been looked after.
Old Mar 25, 2014 | 10:28 PM
B19 JUB's Avatar
B19 JUB
if it is a key problem and light is flashing away then leave ignition on for 15 mins,light will stop flashing and go out then youll be able to start it and get it to a garage
Old Mar 25, 2014 | 10:41 PM
GVK.'s Avatar
GVK.
Most VW/Audi things if problem with immobiliser it will start and stop after a few secs.
Needs fault codes reading , no good guessing..
Usually shows up 17978/P1570/005488 if 'engine start blocked by immobiliser'.
http://wiki.ross-tech.com/wiki/index...8/P1570/005488
If key and or reader coil faulty possibly this code
http://wiki.ross-tech.com/wiki/index.php/01176
Old Mar 26, 2014 | 08:29 AM
markk's Avatar
markk
I would like to bet someone has changed the keyfob battery and the immob chip has dropped out without being noticed (key type dependant) - seen loads like this.
Old Mar 26, 2014 | 08:34 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
If it starts and dies pretty much straight away then I'd hazard a guess at it being immobiliser related too.
Old Mar 26, 2014 | 09:56 AM
chink's Avatar
chink
my petrol audi did this was airflow metre
Old Mar 26, 2014 | 03:25 PM
Fordmad!'s Avatar
Fordmad!
Its the key needs a new one
Old Mar 27, 2014 | 07:44 PM
Or dear.
Old Mar 27, 2014 | 08:27 PM
davidfox280585's Avatar
davidfox280585
That's a 2.0tdi, my a3 is bulletproof and that's a 2.0
Oranoco
12
Oct 2, 2015 02:18 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
