SII Quick
Old Mar 25, 2005 | 10:57 PM
Blunt's Avatar
Blunt
Default SII Quick
As above what 1's to go for and where would like a quaiffe from ive seen um range from £54.00 stock i presume upto £174.00
CheeRS Blunt
Old Mar 26, 2005 | 08:58 AM
James Raby's Avatar
James Raby
Quick shift??
B&M seem to be the ones people rate, although I'm sure rallydesign do one
Old Mar 26, 2005 | 09:37 AM
NUTS RuS's Avatar
NUTS RuS
Got the B&M one one mine at the mo and I hate it. It has very little tension in the neutral position and at the moment it has made things worse than a standard item. Its currently in bits whilst I look at modding it internally, failing that its going in the bin.
Old Mar 26, 2005 | 10:48 PM
Blunt's Avatar
Blunt
Thanx James/NUTRS
Damm LOL it was ment to say quick rack steering
Old Mar 26, 2005 | 11:56 PM
NUTS RuS's Avatar
NUTS RuS
Got one of those fitted too 2.4 turns lock to lock. Makes steering a hell of a lot more precise when moving, but it virtually impossible to park at slow speeds. Came from Quaife over 10 years ago and has so far been re built 3 times upto now.
Old Mar 27, 2005 | 12:02 AM
AndyRST's Avatar
AndyRST
Virtually impossible to get a quaife quick rack or the quick rack kits anymore
But i got my quick rack from Rally design and its a top bit of kit
p.s the mk3 Escort rack is the same as the mk4 Escort rack (only the ratios are different) might help when your looking for a quick rack. Also IMO 2.4 or 2.6 turns lock to lock is about perfect for the escort, mine is 2.2 turns and very heavy under 20 mph but great above that speed
Old Mar 27, 2005 | 12:07 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Tony, I'm kinda gutted to read that. I would like to know more. When you say 'very little tension in the Neutral position', what do you exactly mean?
Old Mar 27, 2005 | 12:30 AM
NUTS RuS's Avatar
NUTS RuS
No need for you to feel gutted at all Christian
With it fitted there is no tension at all in the neutral position. My std linkage springs back to below 3rd gear when you come out of any gear. Made it easy to select 1st as you throw it left and up to get first. With this used in anger I have found myself coming from 5th to 1st looking for 3rd. It can also get reverse straight down from 5th as there is no notch to push it down over.
I binned the two neutral spring tensioners from the normal linkage like it said, but I have it all in bits at the moment looking for a way to refit them again as it may save me a big engine rebuild if I keep it on.
Does yours do it ? Maybe its faulty in some way but it didn't impress me. Dont get me wrong the throw is shorter yes, but it is causing me big problems at the moment.
Old Mar 27, 2005 | 10:14 AM
Blunt's Avatar
Blunt
AndyRSt that's great help mate think mine is 4 lock to lock LOL is this the 1 u got ?
http://www.rallydesign.co.uk/catalog...oducts_id=7315
Nuts cheers bud fancy selling me your's ?
Old Mar 27, 2005 | 10:17 AM
Blunt's Avatar
Blunt
Ps do you have to change the steering coloum as well
Old Mar 27, 2005 | 11:37 AM
Christian and Beccy
#1 in Spelling Club
There must be something wrong, mine is absolutely spot-on. It sits perfectly below third gear and it always returns there without any problems. Because of how short it is, it is far harder to set up than a standard shifter as any adjustment is magnified. Did you follow the instructions to the word? i.e. Did you use their grease in all the right places? The Blue spherical bush is critical, was that fitted correctly with the O-Rings etc? Have you got any play in the cars linkage? Next time I see you at an event, you'll have to see what mine is like.
Old Mar 27, 2005 | 01:27 PM
AndyRST's Avatar
AndyRST
Yep thats exaclty the one i have got (apart from the ratios) I did say mine was a little bit too quick on the ratios so maybe they have adjusted them after my comments lol
Old Mar 27, 2005 | 01:30 PM
Blunt's Avatar
Blunt
Thanx ANDY
u change your coloum as well?
Old Mar 27, 2005 | 02:15 PM
AndyRST's Avatar
AndyRST
no used the normal column but i did have the column bushes replaced when the rack was fitted to the car
Old Mar 27, 2005 | 03:32 PM
Blunt's Avatar
Blunt
Cheers bud
Old Mar 27, 2005 | 04:55 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Blunt, hwo you gunna do all your shopping in it? People have said its a nightmare to park with it.........leave it for the racers, not the wannabes
Old Mar 27, 2005 | 05:18 PM
Blunt's Avatar
Blunt
you know the type loud as a motorbike but could't break traction in a road race
Old Mar 27, 2005 | 05:32 PM
NUTS RuS's Avatar
NUTS RuS
Christian it is/was fitted correctly mate. The original linkage was brand new last year from Ford so I knew that was okay. I have fitted these to 3 Vauxhalls and a Seat Cupra upto now and know it should be better than it is. The blue bush fits fine and the circlip is okay. I think its to do with the centering stuff under the gearstick itself. Its in bits now so I doubt the warranty people would be too happy
I have made a large nylon bush in the lathe today to fit under the collar to tighten it - so will try that next.
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
